Old 08-14-2015, 12:08 PM   #1
apswater's Avatar
Issues after Cruise Control and OBC mod.
I have a 2000 Boxster S that I just modded for cruise and OBC. Those two function work great.
I added a 4 stalk thingy and and replaced the the spring thingy between the column and wheel (technical term of course!)
Now I have an airbag light and no blinkers.
Any thoughts? Does the air bag need to be reset in the computer once disconnected? I suspect the spring thingy may be bad if not...
It is a new blinker switch so I am not sure whats going on there. Before I tear it all apart, I just thought I would ask if anyone has idea.
Thanks.
SciGuy
2000 Boxster S (13K miles)
apswater is offline   Reply With Quote
Old 08-14-2015, 01:06 PM   #2
CrisZenithBlue's Avatar
the airbag light could be if you connected the battery while the airbag was disconnected. the cure for that is to reset the airbag light with a Durametric or Porsche tool. sux if you dont have a friend with one as the dealer or Porsche specialist will charge you an hour labor for what literally takes them 5 minutes.
CrisZenithBlue is offline   Reply With Quote
Old 08-14-2015, 02:08 PM   #3
apswater's Avatar
Ok, I have solved the blinkers, it was the hazard switch. I had a spare.
I did indeed plug and unplug the battery without the airbag plugged in.
I do have a Durametric Pro so resetting the air bag should no problem!
Thanks so much, this forum has been very useful!
SciGuy
Old 08-14-2015, 03:02 PM   #4
apswater's Avatar
Air bag reset, blinkers work.. got cruise control and on board computer... life is good.
SciGuy
Old 08-16-2015, 09:55 AM   #5
Pilot2519j's Avatar
How much did this modification cost you. Cruise control.
Pluralitas non est ponenda sine neccesitate
Pilot2519j is offline   Reply With Quote
Old 08-16-2015, 11:48 AM   #6
apswater's Avatar
If you throw in the Durametric, bad hazard switch, 4 stack switch etc it was about $1200.00
The Durametric pro was about $850.00 but well worth it. I did the work myself so there was no labor.
I took it for a night run down the california coast last night and the cruise control really helped keep it as reasonable speed. I also got about 21 mpg. If it saves one or two tickets it pays for itself!
SciGuy
