Old 08-15-2015, 08:07 PM   #1
More's Avatar
Wheel Bearings.
So I've done my rear right wheel bearing. I just ordered another one on eBay but there was another piece a mechanic said I had to get with it.
Is it a lock nut?
I can't find anything listed under that name on eBay.
Cheers!!
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 08-16-2015, 03:12 AM   #2
He could be referring to the axle nut. Manual recommends replacement.
Deadeye is offline   Reply With Quote
Old 08-17-2015, 01:32 AM   #3
More's Avatar
He sais it's a driveshaft locknut?
Old 08-17-2015, 07:11 AM   #4
Yeah, I've done that.
leftfield6's Avatar
Yes, it is the axle nut, which is on the end of the driveshaft, visible right in the center of your brake disc. It's a "one time use" item, so once you remove it, you have to replace it.
Here is an eBay auction for one. I think they may be cheaper than this at a dealer.
1999 Boxster, Tiptronic, Hard Top, Arctic Silver with Boxster Red Interior
leftfield6 is offline   Reply With Quote
Old 08-17-2015, 08:53 PM   #5
More's Avatar
Thanks guys.
This forum is the best.
Old 08-17-2015, 09:04 PM   #6
Pdwight's Avatar
Proper torque....I broke a large breaker bar doing mine....also get good bearings as this is a job you do not want to do often......F.A.G. , Timken are probably the best bearings to use.
