Old 07-25-2015, 10:58 AM   #1
Fintro11's Avatar
03 Glass top does not close properly
I have an intermittent problem.
Some times when I lower the top the glass rear does not go down properly and causes the top to be stuck open 5 inch before slowly closing itself with a pop.
I have been solving the problem by opening the top up a bit then shutting it again and it usually closes properly after that. I am thinking something has to be adjusted. Anybody else had this problem ?
Old 07-26-2015, 01:40 AM   #2
Maybe needs lubrication. I would start with that as its cheap and easy to eliminate. Had a similar issue a few months ago. Lubricated everything with silicon spray (Simoniz Back to Black) and its been fine since.
www.SNP.org - The Party of Scotland, working for Scotland.
Fatbloke is offline   Reply With Quote
Old 07-26-2015, 08:24 AM   #3
Like Fatbloke said, you might need to lubricate the track. There could be some binding going on there. The arm that controls the top has a rubber bushing that could have gone bad and that too can be causing some binding issues. I suggest you look down in there soon and see what's happening. It could get ugly if you neglect it.
Woody
