Old 07-19-2015, 08:07 AM   #1
1rooster's Avatar
Water pump gasket and bolts?
I have done much research and cannot find any info on these gaskets.Is there a need to use any sealant on the gasket or the bolts when installing?Going to change mine tomorrow.
The hurrier I go the behinder I get
1rooster is offline   Reply With Quote
Old 07-19-2015, 08:11 AM   #2
Buy the metal gasket and no sealand
Duezzer is offline   Reply With Quote
Old 07-19-2015, 08:33 AM   #3
Chuck W.'s Avatar
Agreed. Just completed the job. The gasket part number is 996.106.340.54; $8.88 at Sunset Porsche. There is some trimming required but it is well described in the DIY threads.
I reused the same bolt and have not read that there is a need to replace them.
1995 Porsche C4 Cab
Old 07-19-2015, 08:52 AM   #4
1rooster's Avatar
I got the metal gasket.When I replaced the water pump on my truck instructions said to use a small amount of sealant on the bolts.I was curious about the Boxster bolts.Thanks for the quick replies.
Old 07-19-2015, 01:01 PM   #5
The bolts that go around the pump are of differing lengths - I built a card board stencil to put the bolts in as I pulled them out - You will need a knuckle socket to one to the bolts.
Don't over torque - They don't take much.
Pinch the hose coming in and plug with rag.
Old 07-20-2015, 12:54 PM   #6
flaps10's Avatar
Indeed. Sometimes they don't even take the 7.5 ft-lbs the spec calls for. That crankcase is silver peanut butter. I had to pull mine back off and do two helicoils.
flaps10 is offline   Reply With Quote
Old 07-20-2015, 09:21 PM   #7
I made the mistake of not paying attention to the different bolts around the pump. Post #4 in this thread shows where the two longer bolts are supposed to go.
hancock1701 is offline   Reply With Quote
