-   -   Wheel fitment question? (http://986forum.com/forums/boxster-general-discussions/5770-wheel-fitment-question.html)
docdyh 04-18-2006 11:01 AM
Someone has for sale off their 2002 Boxster S the following wheel sizes
front: 7.5 x 18, offset 50mm (part no. 99336213406)
rear: 10 x 18, 55mm offest (part no. 99336213801)
Is this a correct size, and will spacers be required? Thanks.
TriGem2k 04-18-2006 11:08 AM
They should just bolt right on
docdyh 04-18-2006 11:19 AM
i noticed that your fronts are 7.5..the extra width makes no difference? thanks..
TriGem2k 04-18-2006 11:33 AM
My fronts are 8.5"...But it wont make a difference in your case. Only real difference is my wheel can support a wider tire. Regardless i still run the reccommended 225/40/18...
docdyh 04-18-2006 01:56 PM
thanks..can someone explain what offset means? and the need for spacers when needed?
mjw930 04-18-2006 06:01 PM
Try these links:
http://www.1010tires.com/WheelOffsetCalculator.asp
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
