06-14-2015, 08:51 AM
New momo wheel
Does anyone know the diameter of the factory 3 spoke boxster steering wheel? I got a new momo wheel that measures 350mm. I don't mind if it's a little bit smaller but if it's a lot smaller I don't know if I want to use it. Also will I have any issues with turning off the airbag light when the day comes I put stock whee back in? I like the look of the prototipo wheel and it wasn't too expensive so I thought I would try it out.
06-14-2015, 09:10 AM
I would love to do that but it's again the law here
06-14-2015, 09:17 AM
I am my own mechanic....
Charge your phone!!
No air bag, no pass safety inspection.
'08 VW Touareg T-3 wife's car
06-14-2015, 09:21 AM
I live in California we don't have any type of inspection, just smog. If the airbag light causes any problems with a smog check I guess I could just change it back before the test, I just want to make sure I can get the light turned off
06-14-2015, 02:13 PM
My stock 3 spoke measures 375mm, so the prototipi will be 1" smaller.
01 Boxster S (Sold)
79 SC Targa
73 914
15 Cayman S
06-14-2015, 02:16 PM
Thanks. I think that is a good size
06-15-2015, 01:31 PM
You can't, unless you have a PWIS or Durametric. You can trick the ECU with a resistor arrangement, google it.
06-15-2015, 06:14 PM
I don't mind if f the light is on while I have no airbag, just want to make sure I can get it to go off again when I put the airbag and stock wheel back on if I ever sell the car.
06-15-2015, 07:12 PM
If you go this route, you can remove your airbag lamp from the instrument panel cluster. Takes about 20-30 minutes to remove and reinstall the cluster.
Just put that lamp back in before you sell!
06-15-2015, 07:20 PM
4.7 ohm 1/2 watt resistor between the two pins on the airbag connector and the computer won't know it's gone. for a finishing touch try one of these:
Porsche Embossed Leather Cup for Momo Horn Button | eBay
you do realise that you will also need a hub adaptor, yes?
06-15-2015, 07:25 PM
Yes, I did order the correct adapter for the wheel
06-18-2015, 02:19 PM
I've decided against installing the wheel. My car is equipped with PSM, which my mechanic tells me will no longer work once the airbag is removed.
06-18-2015, 02:51 PM
Plus, it's just silly to remove the airbag...turns out those things can actually save your life...
06-18-2015, 03:17 PM
Agreed. I see no valid reason for that wheel which detracts from the car in every possible way, but that's just my opinion
I'm sure you had your reasons.
06-18-2015, 04:21 PM
Yeah. As a few days went by after I ordered it I started having second thoughts. My stock wheel is in pretty bad shape, any suggestions on a place that can recover it?
02-23-2022, 03:13 AM
Guess I'm late to the party..
Is this a fact? Would the psm be disabled if I remove oem steering wheel/airbag?
Just planning to try the Momo. 07
02-23-2022, 08:08 AM
1998 Boxster Owner
Airbag light does not affect smog check in California.
No it will not.
You will get an airbag light unless you use a bypass resistor. Otherwise everything else stays the same.
02-23-2022, 08:57 AM
Great, thanks Ike!!
