Old 06-08-2015, 06:47 PM   #1
Pdwight's Avatar
Anyone repair their console hinge and not use the kit ?
I have my console out right now for the installation of a short shifter, I figured I might as well repair the hinge where the dirtbag who robbed me broke mine almost a year ago. Looks like the hinge area is just under 3 inches in width, was browsing Lowe's and looking for a solution but before I proceed I thought I should inquire here first.
PS if you are removing your console and have the Bentley manual it is wrong, there is a hidden screw under the useless coin holder that is not shown in the manual.
Also I am toying with the idea of lightly sanding mine and painting it flat black with some of the plastic paint that is now available...anyone tried that ?
Old 06-08-2015, 07:33 PM   #2
98 Arctic silver 986
tommy583's Avatar
I repaired mine using the kit. All the kit contains is a hinge and a few rivets if I remember correctly. I'd imagine a similar hinge and rivets would work just fine.
Old 06-09-2015, 10:20 AM   #3
I've used the plastic black paint from Autozone. Since there were scratches, I had to sand the original finish off. I then sprayed on a couple coats. I sprayed the second coat from a further distance to give it the rough texture. I was impressed with the results.
jklaspok is offline   Reply With Quote
Old 06-09-2015, 01:13 PM   #4
Dlirium's Avatar
Here is the link i used!
Fixed my armrest hinge in less than 25 minutes - Porsche Babblers
Old 06-09-2015, 04:08 PM   #5
Pdwight's Avatar
BIt the Bullet
Ordered the Porsche repair kit
