Old 06-06-2015, 11:05 AM   #1
Fintro11's Avatar
Brake light issue
When pressing the brake pedal the brake lights work pressing further they go out.
Solution-
Under your dash right above is a switch. Rotate it 90 degrees and pull.
Once off remove the connector and open up the plunger and clean the contacts put together and pull the plunger out to the furthest position reinstall fixed
