Old 06-03-2015, 02:13 PM   #1
Glass read window Engine Access
Had my 2001S' top replaced. Now I can't put the top in service position due to the glass window hitting the roll bar when I try to lift the back of the top into position.
I called the installer and he didn't know what to do since he'd never accessed an engine.
Does anyone have a solution?
Iverman is offline   Reply With Quote
Old 06-03-2015, 02:22 PM   #2
JAAY's Avatar
sounds like you got and aftermarket top.
Old 06-03-2015, 02:36 PM   #3
98 Arctic silver 986
tommy583's Avatar
I used a bungee cord. I clip it to the front of the top and below the window. You still have enough room to work on the top of the engine.
Old 06-03-2015, 03:12 PM   #4
I use bungees also and move the top open and/or shut slightly while holding up the back window/rear end of top to get the best roof position for access
luckyed7711 is offline   Reply With Quote
Old 06-04-2015, 10:35 PM   #5
I need to buy a bungee cord. I take a piece of rope and tie it to the roll bar and run it underneath the bottom of the top to move it forward. I take the hard cover off also when I need more room. 6 10mm buts and it gives you a ton of more room.
antny is offline   Reply With Quote
Old 06-05-2015, 06:30 AM   #6
Topless's Avatar
Rope or bungee to hold the window out of the way, easy breezy. A very small Inconvenience for a much improved top.
