Old 05-29-2015, 06:46 AM   #1
Washer fluid on garage floor
I just Attempted to use my windshield washers and nothing out of the nozzles but a puddle on the floor, any ideas what to look for and how to get to it? H
Ptriggiani is offline   Reply With Quote
Old 05-29-2015, 07:08 AM   #2
The hose probably came off the tank, happened to me a couple years back. There is no clamp holding it on. When u push it back on, throw a zip tie on so it doesn't happen again.
mump is offline   Reply With Quote
Old 05-29-2015, 08:49 AM   #3
Is that where the pump is because there is only a leak when the pump is activated, and the headlight washers work fine
Old 05-29-2015, 11:38 AM   #4
still plays with cars...
BoxsterSteve's Avatar
Happened to me too... I put a small worm drive hose clamp on so the hose wouldn't pop off the fitting.
Easy to get at after pulling the front tire and rolling back the rear section of the fender liner.
Six speed 2000 Boxster S
Old 05-29-2015, 12:11 PM   #5
Thanks , will get to it this weekend
Old 05-29-2015, 06:09 PM   #6
Right, it will only leak when pump is activated. It is simple and u will understand when u get in there. At the same time, u will be pissed that Porsche didn't clamp it from the beginning.
