Old 05-24-2015, 06:47 AM   #1
Desnorkle
Quick question, when desnorkling , is the snorkel only on drivers side or both?
Ptriggiani is offline   Reply With Quote
Old 05-24-2015, 06:58 AM   #2
still plays with cars...
BoxsterSteve's Avatar
Driver's side only.
Passenger side is for engine compartment cooling fan.
Try crios mod too for added vroom sound.
Six speed 2000 Boxster S
Old 05-24-2015, 07:07 AM   #3
Thanks, cannot wait to go for ride.
Old 05-24-2015, 08:09 AM   #4
Registered Boxster abuser
healthservices's Avatar
There are these extended elbows that act like silencers on the intake. Remove and place rubber freeze plugs in them. See if you like the added intake roar. It can be irritating at times and this mod is easily reversable
Old 05-24-2015, 09:18 PM   #5
lkchris's Avatar
Don't think mine's been removed, but the sound is already fabulous.
Sure acceleration from low speed but even a highway pass not downshifting.
Very civilized and high class. Don't need raucous.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 05-25-2015, 08:46 AM   #6
Pdwight's Avatar
place rubber freeze plugs in them ????
Old 05-25-2015, 08:48 AM   #7
In the open holes once you remove the silencer
Old 05-25-2015, 08:54 AM   #8
Pdwight's Avatar
I had not heard of this before, I simply removed mine and did nothing else
Old 05-25-2015, 10:45 AM   #9
I hope you are talking just about the snorkel because if you removed the silencer and did not cover the hole then you would have a massive air leak bypassing the mass air flow sensor and not covering the hole.
Old 05-25-2015, 10:53 AM   #10
Pdwight's Avatar
I only removed the snorkle
Old 05-25-2015, 03:06 PM   #11
I only removed the snorkel as described many times in this forum and the sound is intoxicating . I took a 2 hour drive and it ran perfectly with no codes or drivability issues. I am not aware of any need to block the hole, it is the same hole that the snorkle plugs into .
Old 05-25-2015, 03:16 PM   #12
Then you are not removing the items I am speaking of. I am not saying it's better. Its just easier to reverse. The elbows are silencers too, they reduce resonance. Remove the resonaters and now you hear all of it.
Old 05-25-2015, 04:16 PM   #13
Bobiam's Avatar
Tried removing it. Sounded like a 16 yr old with a shop vac trying to sound like a hot rod.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
Old 05-25-2015, 05:11 PM   #14
doctorm3's Avatar
The de snorkel mod has been done by countless people on this forum. Whereas it may not be for everyone, I think that the majority find the added intake "music" rather pleasant......and you really only notice that added sound when you are standing on the gas pedal. Less "spirited" driving and you'll likely not notice a difference. It certainly does not sound like a shop vac on my '01 S......if it did, I would have put mine back in.
doctorm3 is offline   Reply With Quote
Old 05-25-2015, 05:16 PM   #15
No, it doesn't.
Not even remotely close to anything like that.
Are you sure you removed the correct part? Based on your description, you absolutely did not.
Old 05-25-2015, 05:19 PM   #16
Pdwight's Avatar
Mine just sounded better
I like when it is idling I can give the gas pedal a quick tap with my foot and hear the immediate intake or gasp of air...then the better sound.
Old 05-25-2015, 05:24 PM   #17
doctorm3's Avatar
It's as if the engine is taking a quick deep breath. Have to say that I like to do that too!
