Old 05-17-2015, 08:05 PM   #1
Pdwight's Avatar
Irritation noise on startup
It is a tinny noise and when you rev the engine sitting still you hear it...when on the road and really get on it you do not hear it. When I got my secondary cat delete pipes a lot of it went away...but not all....It really sounds like muffler internal noise...perhaps a loose baffle... Does anyone else have this ??
THanks
Dwight
Old 05-17-2015, 08:19 PM   #2
I am my own mechanic....
Timco's Avatar
Heat shields?
Muffler going bad?
Loose coupler?
Sure it's exhaust? Tried removing the belt and running it for a minute or two?
'08 VW Touareg T-3 wife's car
Old 05-17-2015, 08:23 PM   #3
Pdwight's Avatar
Thanks Tim, not the heat shields...had all that stuff off when I removed the rear axles for my bearing job. The couplers were in good condition, I reinstalled them using brand new stainless bolts....I have not tried removing the belt and running....you thinking water pump or ???
Old 05-17-2015, 08:31 PM   #4
Timco's Avatar
I had terrible start up noise. Turned out to be: 1) grooves in cam pulley had mostly filled with rubber. Made squishy sound or squawk sound 2) alternator bearing bad and made crunchy / rattle sound 3) water pump vanes rubbing on block opening until car warmed up. All startup noises, but alternator got worse.
Made a symphony of noises it turned out, but the work truck is a Ford so I was used to that. When those three things were fixed it was silent.
