Old 05-12-2015, 01:28 AM   #1
Oil pooling on the block behind alternator
Just thought I'd post this here as more traffic than in the DIY section but any idea why I have found oil pooling in the cast recesses in the engine block below the intake and directly behind where the alternator sits? Picture in the linked thread.
How to Change your Alternator
MogulBoy is offline   Reply With Quote
Old 05-12-2015, 02:51 AM   #2
Artist, 986S tinkerer
NewArt's Avatar
Most likely a cracked oil filler tube. This is not expensive but a bit of a pain to change.
Old 05-12-2015, 04:07 AM   #3
Thanks. I guess it has to be something high up so will see if I can find a crack or if I can just re-seat it as I moved it when I changed the expansion tank last year.
Old 05-12-2015, 07:23 AM   #4
seningen's Avatar
Check to see if oil or power steering fluid.
m
mike@lonestarrpm.com
Old 05-12-2015, 09:13 AM   #5
oil on top of engine
I also had a similar oil pooling/leaking condition in that area. I had a leak in the oil fill tube joint right at the AOS vent hose location. With advice from this great site, I switched to a screw clamp on that oil fill tube joint. I am monitoring the leak. So far, looks better.
rem503 is offline   Reply With Quote
