Old 05-10-2015, 03:56 PM   #1
Window Microswitch replacement
The window lowers 1/8" about 50% of the time, so I think the Microswitch is bad or failing. Are there any DIY's to replace the switch?
thanks in advance.
Rob T.
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
Old 05-11-2015, 01:26 PM   #2
Does it lower every time? If so, it's not a micro-switch problem. It's more likely the regulator.
jklaspok is offline   Reply With Quote
