Old 05-09-2015, 07:43 PM   #1
ScottStu's Avatar
Water pump went out today.
So, about a block from home the water pump went out. Temp gauge went up to the "0" on 180 and the warning light came on. I already ordered a new pump (one with the plastic impeller) but what kind of coolant do I need? Also, how much do I need? I was reading that you should clamp off the hoses or should I just drain it and start over.
Hopefully it will warm up here in Denver (its snowing right now) since I have to do it under the carport and not in a garage.
ScottStu is offline   Reply With Quote
Old 05-09-2015, 08:07 PM   #2
No noise as warning? When mine went I thought it was the damn IMS...terrible noise.
And SNOWING? Jeebus it's been basically early summer here for the past 1-2 months!
Old 05-09-2015, 08:44 PM   #3
Perfectlap's Avatar
Check out Pedro's site. He has a step by step with photos.
Old 05-09-2015, 08:50 PM   #4
Chuck W.'s Avatar
I just ordered up a water pump and all the extras from Sunset Porsche.
The Part No. for the coolant is 000-043-301-49, $27.99 per gallon. For my '01 S I order up 3 gallons.
ANTIFREEZE (3.79 L) | Genuine Porsche | 000-043-301-49
1995 Porsche C4 Cab
Old 05-09-2015, 10:09 PM   #5
Pdwight's Avatar
which pump ?
Old 05-09-2015, 10:56 PM   #6
I don't know if I would put another plastic impeller water pump back in. That is one of the reasons the stock pump fails. Just my two sense. I think the pierburg is the cheaper better alternative to the OEM pump and it has a composite impeller blade.
antny is offline   Reply With Quote
Old 05-10-2015, 03:20 AM   #7
ScottStu's Avatar
Yeah, we got about 4 inches last night...
I got a couple of squeals at start up, I thought it was the starter. Then it made a noise at the stop light before getting home and the heater temp went down but would get hot if you turned it up so I guess I got lucky.
I ordered a Pierburg off Pelican parts. I hope I did good?
Should be a interesting change out.
Old 05-10-2015, 03:57 AM   #8
Inspect the old pump when you remove it to make sure the impellars didn't break down the last thing you want is pieces of the water pump stuck in the coolant passage ways. Can lead to cracked heads.
rfuerst911sc is offline   Reply With Quote
Old 05-10-2015, 04:48 AM   #9
I am my own mechanic....
Timco's Avatar
I put Pentofrost in mine. Good stuff. Total capacity was 6 gallons as I recall?
Drain it. Change it. Do brake fluid while you're at it.
No snow here. Massive rain.
'08 VW Touareg T-3 wife's car
Old 05-10-2015, 06:05 AM   #10
kjc2050's Avatar
Just curious: what is the difference between "plastic" and "composite"?
And, sorry, it's "two cents," not "two sense."
Old 05-10-2015, 06:11 AM   #11
Beginner
Jamesp's Avatar
I'd never thought of "sense". It could also be "two scents". No wonder English is hard to learn. And composite implies two or more materials used together (e.g. fiberglass), plastic implies a single material injection molded to make the part.
2003 S manual
Old 05-10-2015, 07:32 AM   #12
kjc2050's Avatar
My two cents - Wikipedia, the free encyclopedia
Old 05-13-2015, 04:43 PM   #13
ScottStu's Avatar
Well the pump got lost in the mail, or so they say. They said they sent out another one yesterday so this will put me about a week of not driving the boxster. At least the weather sucks so its not as bad.
Old 05-13-2015, 05:13 PM   #14
CoBeerToad's Avatar
You can get the coolant at O'Reilly's. They had to have some sent over from a couple other stores, but sometimes it beats waiting for the mail.
CoBeerToad is offline   Reply With Quote
Old 05-13-2015, 07:35 PM   #15
ScottStu's Avatar
Yeah, if I don't get the right answer in the morning I will be going over.
Old 05-23-2015, 06:16 PM   #16
ScottStu's Avatar
The people I ordered my water pump took a week and a half to send it to me and it was the wrong pump (metal impeller). Sent it back and ordered one from Pelican and got it in two days without having to pay for speedy shipping. I bought the Pierburg one and could not be happier. It went in very smooth except for that one bolt, like always on anything. I do think that German's must have very small forearms, mine seemed to be too big and scraped against everything.
Good news is the impeller on the old one was Composite and was intact.
Old 05-23-2015, 06:53 PM   #17
I just did mine too, even though it wasn't giving me trouble, just preventative. The old one I took out was a Pierburg also, still in great shape after 60k miles. Put a new Pierburg in, no problem with installation or part condition.
hancock1701 is offline   Reply With Quote
Old 05-23-2015, 09:11 PM   #18
Shacky
Did you go in from bottom or behind seats?
shacky is offline   Reply With Quote
Old 05-23-2015, 10:52 PM   #19
I went from the cabin and underneath. I had issues with one bolt.
Old 05-24-2015, 02:57 AM   #20
ScottStu's Avatar
I went from both the cabin and from under, I need to get better jacks. Using the jacking points I couldn't get the car up enough to get the jackstands in so I slid my ramps under the tires and could not get them all the way to the top. (didn't want to drive it with the pump out)
