Old 05-05-2015, 01:02 PM   #1
p0303 code cylinder 3 misfire
Im going to try to change the spark plug and test the coil, can anyone tell me which plug is cylinder 3? Is this the correct diagram, left one on the passenger side?
liquidimports84 is offline   Reply With Quote
Old 05-05-2015, 01:20 PM   #2
Rearmost on passenger's side (US car).
Old 05-05-2015, 01:37 PM   #3
Not Canada??
Old 05-05-2015, 02:33 PM   #4
well I just pulled the coil and its slightly cracked..ordering new ones, hopefully it will fix the problem
Old 05-05-2015, 04:58 PM   #5
You can clear the code and swap the possible bad coil with another and see if the code follows the bad coil. If so, then you'll know that you found the root cause.
Old 05-05-2015, 06:28 PM   #6
I am my own mechanic....
Timco's Avatar
Why does that diagram show the oil filler tube and manifold intake facing forward? Canadian car?
'08 VW Touareg T-3 wife's car
Old 05-05-2015, 08:24 PM   #7
The diagram is for a 996 engine. The giveaway is the oil filler tube, throttle body intake, and power steering fluid dipstick are all on the belt side. Here is a 996 pic with the air box removed (the red arrows point to the engine mounts).
