-   -   IMS Replacement (http://986forum.com/forums/boxster-general-discussions/57004-ims-replacement.html)
Jedi 05-04-2015 10:38 PM
IMS Replacement
I have a 2004 Boxster S with 25,000 miles on it (purchased new)
I've been thinking of having the IMS bearing replaced also in need of a right rear wheel bearing. I got a quote of 8.5 hours for the IMS and another 3.0 hours for the rear wheel bearing. Just wondering if these times are reasonable or not?
I haven't been following these IMS issues lately and wondering what kits are available, I think the one they quoted is an LN Engineering ceramic double row.
They also quoted doing an oil change and replacing the rear main seal, is this necessary or might as well do it while they are in there?
Thanks in advance for any advice
Jim
Porsche9 05-04-2015 10:41 PM
Assuming you have a manual transmission all of it sounds right. Doing the RMS makes sense since they are right there and the part is cheap.
Jedi 05-04-2015 10:45 PM
Hi Porsche9
Thanks for the quick response, yes it is the manual 6 speed
Jim
KRAM36 05-04-2015 11:04 PM
To me, this is the only IMSB replacement I would use.
IMS Solution for Single Row IMS MY00-05 - IMS - Products LN Engineering
Get it cheaper here
Porsche 911 Boxster Intermediate Shaft Bearing Update Kit IMS Solution 996 986 | eBay
Steve Tinker 05-04-2015 11:06 PM
Jedi, you have a single row bearing if your car was manufactured in 2004.
Luv2Box 05-05-2015 07:18 AM
Isn't there a double row replacement for the single row IMS? If so wouldn't that be more prudent to install?
clickman 05-05-2015 08:45 AM
There are as many opinions on which IMS replacement to use as there are for type of oil to use.
Too bad there isn't enough data out there on the ones installed, without unknown external influences like the quality of the installer.
Gelbster 05-05-2015 08:47 AM
You are thinking of the "Single Row Pro" ? -which is a staggered 2 row = 1-1/2 rows.
There is a new version of the Solution coming soon to deal with the misalignment issue.Ask LN.?
Jake Raby 05-05-2015 09:03 AM
The Single Row Pro is a true dual row bearing. It is of European width and is a custom made unit. It is not a 1-1/2 row bearing.
This unit must be installed with the Faultless Tool and allows the use of a dual row bearing within the confines of a Single Row shaft. No modification to the shaft or engine is required.
The ultimate is, and always will be the IMS Solution. Its also the only patented IMS Retrofit on the market.
thstone 05-05-2015 09:07 AM
Oil change is expected as they will want to remove the filter and check for metal before installing anything and they might as well change the oil while they have the filter out.
Replacing the RMS is standard practice almost anytime that the trans is out since its a cheap part and an easy replacement.
Last, your clutch should be in good condition with only 25K miles, but be prepared for the shop to suggest changing it as long as everything is apart.
clickman 05-05-2015 09:10 AM
That's the right thing to do... Do they all do it as matter of course?
Jake Raby 05-05-2015 09:20 AM
Don't even think about dumping the old oil back in after an IMSR procedure!
clickman 05-05-2015 01:35 PM
It was the removal of filter and checking for metal I was referring to. And the pan.
mikefocke 05-05-2015 04:47 PM
And the quality of the engine the kit was installed in.
Jake has posted on another forum of a tool he has developed to measure the relationship of the crankshaft hole and the IMS hole in the block. He is thinking, possibly after seeing multiple failures in a given engine and searching for the reason, that slight manufacturing variations make a difference. In his shop, he will now not install any IMS kit into an engine which fails his new test.
If this is true, then once you get in and see the condition of your current IMS, you can predict how your replacement will fare.
mikefocke 05-05-2015 04:51 PM
LN makes 3 bearing replacement kits for your car. In order of price, the LN single row, the Single Row Pro which is the double row and the IMS Solution which is the flat bearing (like is used on the other end of the IMS shaft) version with added externally supplied oiling.
mikefocke 05-05-2015 04:54 PM
If they propose replacing the clutch, ask for the measurements that support that suggestion. Not that the parts are that much of the total job and it is cheap to do once you have the transmission sitting on a workbench. But just to let them know you want fact based opinions, not ones that are designed to add to their bottom line.
token 00 05-05-2015 05:02 PM
Just had the single row pro installed with clutch, RMS, flywheel and AOS at Chris' in Seattle. New oil and filter - yes! Lucky to have one of the preferred installers in my backyard. Only have a couple hundred miles on the new bearing - so far so good.
I'd get the clutch done too if you're going in for the IMS. At the very least you should be saving yourself a new flywheel purchase and an additional 8 or so hours of labour in the future.
Cheers,
Token
BobRickel 05-05-2015 07:28 PM
I used the EPS IMS solution after doing extensive research on all of the options available. Mine has been in for about 9K miles at this point. I run the heck out of my 1997 and thus far no problems. It only had 40k miles on it but I was concerned about dependability so I replaced all the rubber coolant hoses, the front motor mount, the Air/Oil separator, the water pump (was starting to wobble), the plugs and plug tubes, the rear main seal and the fuel and air filter and anything else I could think of. Here is a video with a cutaway of the EPS IMS solution.
https://vimeo.com/89968767
KRAM36 05-05-2015 07:40 PM
That's the one I said I'd go with, IMS Solution.
Retroman1969 05-06-2015 10:04 PM
I do have a question about this....
Most info on the IMS Solution has it listed for '00-'05 engines. Is there not a version to fit the earlier dual-row engines?
Sorry, I did a search and couldn't find this particular question addressed. If I do an upgrade to either or both of my '99s I'd like it to be the most robust and permanent upgrade possible. ;)
clickman 05-06-2015 10:27 PM
The IMS Solution only fits single row engines. 97-99 are definitely dual row, and 2000-2001 can be single or dual row.
bachmoza 05-07-2015 04:46 AM
Anxious to hear from Jake!
+1,
I've already retrofit a LN dual row ceramic preemptively to my 99 tip a year ago. Could not wait without any promise for unanswered hope" IMS Solution for earlier double row engines"!
I contemplated Flat 6 Innovation or Jake has probably renounced to develop it because of lower failure rate of early double row IMSB:dance:
or limited numbers who'd exchange it in there old cars.. so low marketability!,
or there would be any technical difficulty ? least possible presumably.D
Anyway, I'd take that IMS Solution if available, for my next exchange.
Retroman1969 05-07-2015 05:36 PM
Now I have a definitive answer, thanks!
It probably is a factor that the reliability of the dual row plus the (I'm guessing) 100% success rate so far of the dual row retrofit has aided in the decision for no IMS Solution for the earlier cars.
I'm likely to retrofit the weekender when clutch time comes, but the daily driver is still up in the air. With nearly 140,000 miles on it, it would be my luck that I'd retrofit it, and then something else would give out and shred the engine. I'm debating if i should just drive it Til it dies, then install an upgraded engine, or look for a deal on a 2009 model for my next daily. ;)
Jake Raby 05-07-2015 10:09 PM
We developed a dual row IMS Solution from the beginning. We did not produce them because early cars had lesser values and the demand was low. Early cars have made a big rebound in the past 3-4 months and we are seeing constant IMS Solution interest from those owners.
BUT just last week our biggest distributor requested that we make them a run of Dual Row IMS Solutions. They ordered enough to fill a whole production run. As of today the material was ordered, and around 6 months from now they'll be available.
I'll be doing a dual row IMSR clinic as soon as we have the parts in hand :-)
bachmoza 05-08-2015 03:05 AM
Retroman:
- That is cool, lucid and all possible measures. Thanks for reply.
Jake!
What an exquisite marvelous step!
Take off my hat to you!
CK
tnoice 05-08-2015 03:36 AM
I went with the IMS solution for my 04 S and have absolutely love it. It has given me piece of mind and Jake and his company took great care of the car not only when they had it, but also as they shipped it back to me.
Retroman1969 05-08-2015 05:15 AM
Wow, cool news Jake! :)
Will be looking forward to its release, thank you!
Bachmoza, looks like you were right about age and low marketability being factors, at least up until now. ;)
