Old 04-30-2015, 02:46 PM   #1
Odometer/Trip meter
The lower left digital display on my instrument panel that displays odometer/trip meter has gone dark. Does anyone know which fuse supports that? Bentleys does not break it out
Bdrude is offline   Reply With Quote
Old 04-30-2015, 03:19 PM   #2
The bulb is out. You will need to pull the cluster to replace.
Old 04-30-2015, 08:37 PM   #3
+1. I bought a 98 Boxster years ago on the cheap ($4,800). One of the things that the owner listed is there was no odometer readout. When I went to look at the car, it was sitting as just the right angle with the sun behind the car that I could make out the faint display.
I pulled the cluster and replaced the bulb.
Also note that if you ever lose your cruise control function, it'll mostly likely be a bad bulb (really)!
