Old 04-13-2015, 10:30 AM   #1
2 fast 4 U
New coolant tank
Ok so I just received my replacement tank to replace the defective one I got the first time around. Oh joy I get to do this job twice. I was wondering if anyone know a way to test the tank for air leaks before installing it?
Drive it the way it's meant to be driven!
2000 Boxster S
redeye280z is offline   Reply With Quote
Old 04-13-2015, 08:29 PM   #2
I think Lauren Bacall gave the proper advice in "To Have or Have Not."
https://www.youtube.com/watch?v=KY15R3yHBEI
Trying to keep it light.
DBear
dbear61 is offline   Reply With Quote
Old 04-14-2015, 01:01 PM   #3
Grim1ock77's Avatar
I feel your pain
I did this same thing. I purchased one from Amazon that did not work. I had tons of vapor off of it and the coolant kept boiling over. I finally broke down and ordered a genuine Porsche one from Suncoast that provides a warranty on parts.
______________________
1999 Black Boxster
Grim1ock77 is offline   Reply With Quote
Old 04-14-2015, 03:01 PM   #4
2 fast 4 U
I received a replacement tank from the company at no charge but I am wondering if I will have the same issue. I really don't want to do this job again.
2000 Boxster S
Old 04-14-2015, 03:21 PM   #5
Artist, 986S tinkerer
NewArt's Avatar
Do you know what the problem was with the first tank? Was there a crack or other discernible defect?
You could put test caps on the nipples and pressure the new tank to 15 lbs, or vacuum the tank to 25 lbs with the airlift) to test for leaks before you install it.
Old 04-14-2015, 04:42 PM   #6
Pdwight's Avatar
I have yet to do this job
But from the threads I have read is high on the "I need a third and fourth miniature hand" to do I would not want to do it over to save some money. I will buy a genuine Porsche from Pelican when I do mine. THere was a recent thread about someone who cut the time down to two hours by destroying the tank as he removed it
Old 04-15-2015, 01:10 AM   #7
2 fast 4 U
There was a small defect where the the plastic was molded together right near the over flow tube. The company sent me a new tank and I installed it last night. I am getting pretty good at it took me only an hour and a half to install. There is a leak from the new tank as well but this time coming from the valve I suspect. I will have to check the o rings tonight.
2000 Boxster S
