Running lowered boxster in Quebec?
Frost heave season is here and it has me second guessing my plans to lower my box. Any Quebecers running lowered having regrets? Should I forget it, our roads are just too bad, or just wait until the roads flatten out before driving with a 30mm drop kit?
Bump and add any frost heaved area with lowest bidder roads.
That depends on where your stock suspension is at. If you've got an S suspension I wouldn't go lower for street use where you are. If you have a standard suspension, you've got a centimeter or two to play with. I'm running an S in Manitoba and every once in a while I'll hear the bottom of the front bumper scrape.
Stock base suspension and the struts have given up the ghost commuting on our goat trails they call roads. New struts and springs will be ordered but want at least the ROW M030 drop if not 25 mm at each end.
| All times are GMT -8. The time now is 06:38 AM. |
