04-09-2015, 03:00 PM
1998 Boxster Owner
1998 Boxster doesn't have manual Spoiler switch - is this common?
So I trolled many threads and could not find the answer - is it common for a Boxster not the have the Spoiler Toggle switch. I opened the fuse box today since my spoiler is not working and it's just empty space where the switch should be.
I plan on adding 2 new relays since I did the #3 and #9 swap and it did not work
04-09-2015, 03:05 PM
My 2000 Boxster base has the spoiler toggle switch.
04-09-2015, 03:58 PM
Registered Boxster abuser
you should not have to open the fuse box.
04-09-2015, 08:31 PM
Lower left, see the button?
04-09-2015, 08:34 PM
That is the up-down button. This one is on a 98 though so yours maybe a little different
04-10-2015, 12:14 AM
Did it come with the factory aerokit that deletes the active spoiler in favor of a longer trunk lid with fixed spoiler?
04-10-2015, 04:08 AM
I went and checked my factory aerokit Boxster when I read the post.
The switch is still there on mine. Just deactivated.
04-10-2015, 06:23 AM
I had trouble with this too. I could not find the switch, and my fuse cover was missing. I finally did find the switch danging behind the fuse panel. All is well now. so keep looking.
1999 Boxster Base Ocean Blue Metallic 85k mi. New to me on 04/2014 w/ 83k mi.
04-10-2015, 08:17 AM
Same thought - look behind the surround for the fuse box, four screws to remove it.
04-10-2015, 09:32 AM
1998 Boxster Owner
Excuse my ignorance but I have no idea. (I am not familiar with the factory aerokit) - I will look it up.
@Healthservices - I appreciate the pics and the sarcasm but like I mentioned the switch is missing. The slot where the switch is mounted is empty. I just recently purchased the car used from a Porsche dealership and it did not come with the owners manual. I am still getting familiar with the ins and outs of the car.
04-10-2015, 09:35 AM
I would look behind the panel than as Jschindle mention as there is a chance the fuse panel was removed to do some diagnostic work and not re installed correctly when replaced
04-10-2015, 12:31 PM
2003 S, Arctic Silver, M6
I'd question the dealer you bought it from as to what the hell gives here. There is a reason there is an active spoiler that kicks up at 120 KM/hr on this car and The Porsche dealer should know it is a stabilty and safety issue.
04-10-2015, 03:16 PM
1998 Boxster Owner
Noted! Thanks I will call Porsche
04-13-2015, 03:26 PM
I'm surprised that a Porsche dealer would sell 17 year old Boxster on the lot. here is some more help if you are still having issues...
remove 4 screws and pop surrounding panel NOT THE FUSE PANEL ITSELF...
This is the plug...
This is where it plugs into the switch. since yours is missing I would contact 986 Forum - for Porsche Boxster Owners and Others - View Profile: itsnotanova get a new one or source one as it is only a three wire switch.
04-15-2015, 10:40 PM
I have wired several boxsters and 911's wings to manually control them. It takes 2 relays and an extra window switch. It's pretty simple.
04-15-2015, 10:55 PM
When I bought mine I thought I was missing mine also. Like others have said it probably fell behind. That is where I found mine. If you don't find it let me know because I actually have an extra I ordered.
04-19-2015, 09:56 AM
1998 Boxster Owner
So I removed the relays and re-inserted them and now my spoiler works. I put scotch tape over the spoiler as others have done and bam the spoiler works. Antny I'll take you up on your offer if in fact the switch is missing. I know its an easy task but haven't had time to remove the panel to see if the switch fell behind.
Healthservices thanks again for the detailed pics. I know members get annoyed with noobs  Yeah finding a 98 Porsche from the dealer was a surprise. It was a trade in from what they claimed from a long time customer. Could have been lip service. I did a little homework and asked them to give it a new poly belt. They performed the full 60k service and gave it a new set of tires. I couldn't pass it up so I took the plunge. The previous owner left it all stock - other than wanting a short shifter I am gonna leave it stock including the crappy sound system.
Thanks again to all who helped a noob!
04-19-2015, 10:09 AM
Just let me know. I don't want you to make the mistake I did and bought one before taking the panel apart and finding mine.
04-19-2015, 12:10 PM
Spoiler
I tell you if I could find a spoiler I really liked I would install one and get rid of the mechanical contraption that weighs so much.
04-19-2015, 01:26 PM
Mine Didn't
My '98 did not have a manual switch for the tail. I had to install one.
