Old 04-08-2015, 05:16 PM   #1
Radio code help
Hi All,
I have a Boxster 2001 with a CDR-220 radio, I just had the steering wheel replaced and I guess the garage disconnected the battery. It now need my radio code, can anyone help??
Thank you.
Dgrange is offline   Reply With Quote
Old 04-08-2015, 05:32 PM   #2
Heiko's Avatar
Originally Posted by Dgrange View Post
Hi All,
Thank you.
Send me the serial number for your radio and I will get you the code...
Previously owned:
Old 04-08-2015, 05:33 PM   #3
Hi, how do I get the serial number?
Thank you.
Old 04-08-2015, 05:40 PM   #4
Heiko's Avatar
Start with radio off.... now turn on and immediately after hold down button marked TP for about 12sec. "Becker 1" will show on display; now rotate right selector knob and it will display the Becker mod#, serial# etc.
I need the serial number displayed....
Previously owned:
Old 04-08-2015, 05:46 PM   #5
Hi, it's 4462 and serial number Y5054078
Massive thanks!
Old 04-08-2015, 06:41 PM   #6
Heiko's Avatar
9049 should work for you
Previously owned:
Old 04-09-2015, 01:47 PM   #7
It did! Thank you so very much! I really appreciate you helping me!
Old 04-09-2015, 02:12 PM   #8
Heiko's Avatar
No problem
I wrote mine on the side of the cigarette lighter :-) helps me remember what it is and its a convenient spot :-)
Previously owned:
Old 04-11-2015, 05:31 AM   #9
Very good idea, will do the same today.
Old 04-11-2015, 08:57 AM   #10
Mine had the radio code hand-written on the top right of the options code label under the front hood. I believe this may have been part of dealer-prep in some dealerships. It also had "006" hand-written in the top left. Does anyone know what the "006" represents?
newBgeek is offline   Reply With Quote
Old 04-11-2015, 09:16 AM   #11
Need For Speed
KRAM36's Avatar
It's a British Secret Service car used by one of their other {Bond} members!
2003 Boxster S
Old 04-11-2015, 09:24 AM   #12
LOL now I know what that red button is for under the stick shift cap!
Old 04-19-2015, 11:42 AM   #13
2000 Boxster
Radio code
i have a CDR 220 type 4462 serial # YS036833. Had the battery disconnected in the winter and need the code. Can you help?
Boxstergrrl is offline   Reply With Quote
Old 04-19-2015, 01:06 PM   #14
Heiko's Avatar
9101 is your code :-)
Cheers
Heiko
Previously owned:
Old 04-25-2015, 03:15 AM   #15
Boxster Radio code
I just got a 2001 boxster CDR-220 type 4462 serial Y5054217
XKNIX is offline   Reply With Quote
Old 04-25-2015, 03:46 AM   #16
Heiko's Avatar
5064 should work for you
Heiko
Previously owned:
Old 04-25-2015, 07:34 AM   #17
I have a CDR 220 type 6624 serial 15000067. Can you help me out?
cardiffgiant is offline   Reply With Quote
Old 04-25-2015, 07:50 AM   #18
Heiko's Avatar
4130 is your code
Heiko
Previously owned:
Old 04-25-2015, 08:06 AM   #19
That one didn't unlock it. I'm sorry, I see what I did. I used the model number instead of following the instructions in the thread. I went back and held the TP button and toggled through the information, the type is actually 4362 and the model is 15000067.
Old 04-25-2015, 03:07 PM   #20
Heiko's Avatar
Ok no problem all I need is the last 4 numbers of the serial number. I will send you
The code when I'm back on my system at home later
Cheers
Heiko
Previously owned:
