Old 04-03-2015, 08:33 AM   #1
Headers for 97 tip
I have to ask it here in general forum since I did get much response in the performance forum....anybody have ideas about headers that will work with a '97 tip? I have read they can be made to work with modification - what is the mod and what is involved? For info - the '97 had a single cat that is downstream from the exhaust manifold so a simple header swap would be pretty easy (modification aside)
Thanks for the help and ideas-
brewerbry is offline   Reply With Quote
Old 04-03-2015, 10:04 AM   #2
Xpit77's Avatar
Headers
I put some on my 99 tip. Same cat setup. The only issue with tip is there is a tranny line that will almost touch the header. My tech was able to move it a bit. We put some heat shield cloth around the line. Worked. Some companies stamp a little dent in the offending pipe for clearance mine didn`t.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 04-03-2015, 11:48 PM   #3
Need For Speed
KRAM36's Avatar
I was looking into this for you. It appears on a 97 that headers will reduce lower throttle response and torque and just give a little more HP in the high end of the RPM range.
Not sure this is worth pursuing.
2003 Boxster S
