Rear Brake Rotors
Hello,anyone know if these rear brake rotors fit 03 base Boxster? part #987 352 401 01 Sebro Drilled brand.
Its just i can get these cheap in my city off a guy. Sebro No 205828C. Says on box fits 2004-2012 Boxster/Cayman/911/997. If anyone knows,much thanks.
Probably not. Your base 986 has 292mm discs in the rear, while the 987 has 299mm.
if the brakes are compatible with the 911, they are for the s models, not the base models. if you are looking for the drilled and slotted rotors, I would recommend the powerstop rotors, they are relatively inexpensive and performed flawlessly on my 00 base model
| All times are GMT -8. The time now is 01:54 AM. |
