03-25-2015, 03:48 AM
#41
Beginner
Originally Posted by Topless
Maybe have a shop scope the offending cylinder and see what's up. If it's just a valve spring it's a pretty easy fix. If a grenade went off in there then swap the motor and keep on driving. Lots of decent motors sitting at dismantlers still for not to much money. I'm not ready to dump the car yet.
Find a local indy shop with lots of 986 experience through your local PCA.
+1 or buy an inexpensive scope and do it yourself. If the piston is damaged or there is anything in the cylinder that should not be, the cost for repair is very likely more than the car is worth. something beat up that spark plug and it wasn't a non functional valve. Pulling the valve cover off is more work than just scoping the cylinder.
2003 S manual
03-25-2015, 04:29 AM
#42
Need For Speed
That's way I'm saying pull the spark plug. If it looks like that he has bigger issues. If not then fixing it might be worth it.
2003 Boxster S
03-25-2015, 06:51 AM
#43
15 grand for a special tool
I think you need to talk to someone else....drop the oil , remove the plugs.....it is not kryptonite ....it will not bite you ....jump in....what do you have to lose
03-25-2015, 08:40 AM
#44
Registered Boxster abuser
go to Harbor freight and get a borescope or if time is not an issue anymore ...
5M 6 LED Waterproof USB Borescope Snake Inspection Endoscope Tube Camera Mirror | eBay
Then pull the coil, plug, and take a peak.
Otherwise tow it down here, I would not mind playing with it. Give me 1700 and Ill do a straight R+R, of course thats not including parts or any add ons you want to do. I even have a inexpensive tow guy.
03-25-2015, 08:58 AM
#45
Need For Speed
Originally Posted by healthservices
What a champ!
2003 Boxster S
03-25-2015, 10:41 AM
#46
Originally Posted by KRAM36
Pull the spark plug from from cylinder 4, since that's the cylinder the had no compression in your first post and see if it looks something like this.
While doing the diagnostic the shop removed and replaced all plugs with new plugs to rule-out any problems coming from the plugs. He didn't mentioned any major damages to the plugs except the following in his report: "R&R all spark plugs, found plugs to be carbon tracked"
03-25-2015, 11:17 AM
#47
Everyone should have a borescope. Absolutely invaluable in situations like this (or about a million others).
I use mine all the time.
I also have that USB camera endoscope that healthservices linked above and it works just fine. It's a little more awkward to need to have your laptop with you to view the image, but not terribly inconvenient.
03-25-2015, 12:02 PM
#48
Need For Speed
I would say that's somewhat good news. Let healthservices have a crack at it if you have the funds.
BTW: I searched Harbor Freight for borescope and they didn't show one.
2003 Boxster S
03-25-2015, 12:24 PM
#49
Sometimes called an "inspection camera".
http://m.harborfreight.com/digital-inspection-camera-61839.html
03-25-2015, 12:31 PM
#50
Need For Speed
Originally Posted by particlewave
Thanks! Very cool, I want one just to play with it now lol.
2003 Boxster S
03-25-2015, 01:11 PM
#51
Located in Central Mass.
'00 Boxster
03-25-2015, 01:45 PM
#52
Don't forget the 20% off coupon you can get almost anywhere!
03-25-2015, 01:48 PM
#53
Sorry to ask but what is Healthservices (beside the obvious medical term)?
03-25-2015, 02:03 PM
#54
Actually, I'm pretty disappointed and angry at the shop owner because when I asked him if he used a borescope too look into the cylinders to see if he could find any damage he told me that he didn't because it's too difficult and too deep on those cars. Is it really?
03-25-2015, 02:04 PM
#55
Need For Speed
Healthservices is the person who if offering this help to you.
2003 Boxster S
03-25-2015, 02:06 PM
#56
Quick question: Is it possible to remove the camshaft cover without taking the engine out of the car?
03-25-2015, 02:11 PM
#57
Yes, but it is very tight and requires the use of special cam holding tools to prevent damaging the cams in the process.
03-25-2015, 02:17 PM
#58
still plays with cars...
Sounds like you need a new mechanic. Seriously, a boroscope is an almost-necessary tool for internal inspection and diagnosis.
His 27 hour labour quote likely includes engine removal and a total tear down. Sure beats using an inspection camera!?
Six speed 2000 Boxster S
03-25-2015, 02:27 PM
#59
Sorry KRAM36, this thread became so long I didn't even notice that Healthservices is a member and responded to one of the post.
03-25-2015, 02:30 PM
#60
Thanks for the offer. I'm located in the Bay Area, where are you located?
