03-22-2015, 09:26 AM
#1
Max tire size on 9x18 rear wheel
Car: 2000 Boxster base
Wheel: 9x18 Turbo twist Porsche Factory Wheels
Rear suspension & camber: Car has stock suspension & camber alignment.
Currently I have 265/35/18 on the rear wheels.
Qn: what is the max tire size I can install in my 9x18 wheel without having to use any spaces, fender rolling, any rubbing and performance issues?.
Tire preference: Michelin Pilot Super Sport tires. Car will be used in both track and street.
Following are some options, let me know what you think:
Michelin Pilot Super Sport 275/35/18
Michelin Pilot Super Sport 285/35/18
Thank you.
Chamilka
03-22-2015, 09:30 AM
#2
Need For Speed
2003 Boxster S
03-22-2015, 09:46 AM
#3
Originally Posted by KRAM36
Thank you, I didn't realize 265 is the max, I though I have heard people using 275 but may be that for 10 inch.
Thanks for you input and the link.
03-22-2015, 10:03 AM
#4
Need For Speed
I'm not saying 275 won't fit. I would worry about the contact patch not being as good (since it will be putting a bow in the tire) as if you were running a 265 tire.
EDIT: I am curious as to your tread wear using 265's on a 9" rims.
2003 Boxster S
03-22-2015, 05:00 PM
#5
Rennzenn
I've never had a problem w/ 275s on my 9" turbo twists.
Rennzenn
Jfro@rennzenn.com
03-22-2015, 07:03 PM
#6
Need For Speed
Do you deflate the tire? How are you getting the tire to get full surface contact? A 275 tire is 10.83 inches wide.
Do you happen to have a close up picture of this combo?
2003 Boxster S
03-23-2015, 06:34 AM
#7
Rennzenn
Here are a couple of shots of 275 on 9"
Just for kicks, here's 235 on the 7.5" wheel
Rennzenn
Jfro@rennzenn.com
03-23-2015, 07:01 AM
#8
Need For Speed
By this picture it looks like your under inflating the tire and still not getting full contact of the tire and it's showing the bow.
2003 Boxster S
03-23-2015, 07:06 AM
#9
Registered Boxster abuser
I had 295s on my mercedes with 9 inch wheels. There is the recommended best size and then there's everything else
03-23-2015, 07:20 AM
#10
heck, many cobra guys ran a 315-35-17 on a 17x9 inch rim until the aftermarket companies made replicas to 17x10.5
Not saying you should put such a big tire back there but just because someone says its not ideal does not mean its not possible.
03-23-2015, 07:31 AM
#11
Not true. The Michelin 275/35 is suggested for a 9-11" rim.
03-23-2015, 07:45 AM
#12
Need For Speed
It is too true. I said the recommended size, not what you can get fit on a rim.
Understand this, 9" rim, 275 tire is 10.83 inches wide. That's not a proper combination. Not even close. 265 is stretching the the recommended size for a 9" rim.
Please by all means ignore the tire/wheel site I posted.
This is the wheel I have decided to go with on my Boxster. Notice the rec tire size, from Tire Rack? 265 and that's on a 10" wheel. However I will be going with 275 tires on the rear.
2003 Boxster S
03-23-2015, 07:47 AM
#13
Need For Speed
I never said it was impossible. People do unrecommended things all the time, doesn't make it correct.
2003 Boxster S
03-23-2015, 08:14 AM
#14
Not attacking just saying. And not correct does not mean it does not work. Just because a 265 will work ideally with a "XX" inch rim does not mean a 275 won't work better even though a 275 may work better with a larger rim. I love the big tire look, but in many cases it just does nothing but deter the performance.
Here is my old car with the big tire. Yes I know today most are into the other direction and like the stretched tire look but I'm old school.
03-23-2015, 08:21 AM
#15
Need For Speed
Not attacking just saying. And not correct does not mean it does not work. Just because a 265 will work ideally with a 10 inch rim does not mean a 275 won't work better even though a 275 may work better with a larger rim. I love the big tire look, but in many cases it just does nothing but deter the performance.
I'm sticking within the recommend size for those wheels. 235 front, 275 rear. This combination gives a better front to rear tire speed rotation too.
The are lots of things to look at when buying tires, way more then how wide a rear tire you can fit on a wheel.
2003 Boxster S
03-23-2015, 08:37 AM
#16
Need For Speed
Yeah, I don't get the stretched tire deal either. Looks hideous to me.
2003 Boxster S
03-23-2015, 08:38 AM
#17
Rennzenn
On the rears I keep pressures at 34 psi. The car does have -3.2 degrees camber and it wears the inside edges. Since these tire are directional, about mid tire life I'll flip the tires on the rims and put them on the other side.
Rennzenn
Jfro@rennzenn.com
03-23-2015, 08:39 AM
#18
Loss of torque multiplication is the unavoidable downside of running taller than spec rear tires. This is very noticeable on 986's. That leaves a 285/30/18 as the only option along with 10" X 18" wheels. Now the car resists rotating into turns!
03-23-2015, 08:46 AM
#19
Need For Speed
What's the recommended psi for those tires, 50?
2003 Boxster S
03-23-2015, 08:55 AM
#20
I tell you what, the 275/295 combo on the benz sure was undrivable in the snow! Esp since they were summer tires they just floated on top of the snow... lol
And just to re-emphasize, when you have so much camber with a wide tire, and low sidewall, you will get a lot more tire wear than a narrower tire.
