Old 03-17-2015, 02:32 PM   #1
woodsman's Avatar
axle hop
Anytime I revved my Boxster and launched from a standstill I'd get wheel-hop. I just took a 996 TT for a test drive and no matter what I tried it just hooked and went. Does your Boxster launch cleanly at say 3-4000 RPM's?
Old 03-17-2015, 02:39 PM   #2
bwillia080261's Avatar
My 01 Boxster S does not wheel hop under those conditions. How are the struts and bushings?
bwillia080261 is offline   Reply With Quote
Old 03-17-2015, 04:28 PM   #3
Luv2Box's Avatar
Wheel hop stopper.
TechnoBrace
Luv2Box is offline   Reply With Quote
Old 03-17-2015, 06:06 PM   #4
Need For Speed
KRAM36's Avatar
Wider tires.
2003 Boxster S
Old 03-17-2015, 06:10 PM   #5
Front motor mount.
'99 black 986
Old 03-17-2015, 06:25 PM   #6
Need For Speed
KRAM36's Avatar
Front motor mount.
He just put in the new style motor mount. I asked him if he got the side stops with it and he never answered back on it.
2003 Boxster S
Old 03-17-2015, 06:34 PM   #7
When I had wheel hop on my 2001S it turned out to be a bad shock/strut. Swapped it out and problem solved.
'01 Boxster S - Silver/Gray
'58 356A Cab - Fjord Green/tan
Parrot356 is offline   Reply With Quote
Old 03-17-2015, 07:16 PM   #8
Topless's Avatar
Boxsters all wheelhop if you really get on it. Not good for your pinyon bearing and may lead to failure. Learning to do a smooth launch without damaging the clutch or transaxle is a tricky business. If you like to do a lot of stoplight launches, add an LSD or start shopping for a spare trans.
FYI: A 996 TT is all wheel drive with LSD. They always launch great.
Old 03-17-2015, 09:34 PM   #9
Originally Posted by KRAM36 View Post
Wider tires.
mine is a 99 2.5l with wider tires and it flat won't break traction on dry pavement. I have to be on wet pavement to get it to break loose. My son got the rear wheels to hop last night when he was accelerating in 2nd and missed 3rd and hit 1st instead. I hate teaching him how to drive a standard transmission in this car. I need to get the 76 914 running this summer so he can learn on that one.
Old 03-18-2015, 10:53 AM   #10
I don't get any wheel hop with my '99 which has 19' on it with 275's on the back.
I know just where the clutch will "bite" and can launch fast and hard smoothly with no slip...
also, if you're going to teach someone to drive a sports car, learning how to correctly blip the throttle down shifting takes a huge load off the drive train...
tim
timlawton is offline   Reply With Quote
Old 03-18-2015, 11:37 AM   #11
woodsman's Avatar
Installing new ROW 030 struts helped a little just as a new front motor mount (had to re-use the side pieces) did. I always wondered how the newer cars equipped with the sports crono pac could spin to something like 6000RPM and than launch netting 0-60 times in the magical 3's and4's. For a short time I ran some old fronts (225's) on the rear and could hardly notice a difference (including launching)except as cornering speeds increased (and especially during transient maneuvers).
Old 03-18-2015, 11:43 AM   #12
woodsman's Avatar
Originally Posted by Luv2Box View Post
Wheel hop stopper.
TechnoBrace
Interesting idea. It worked for you?
Old 03-18-2015, 01:23 PM   #13
still plays with cars...
BoxsterSteve's Avatar
He hit 1st on a 2nd gear upshift?!
Seriously, buy an old Corolla, Civic or Cavalier for him to beat up on and wreck until he figures it out.
Probably less $$ that way than a clutch & tranny for the Boxster...
Six speed 2000 Boxster S
Old 03-18-2015, 02:01 PM   #14
edc
550 Anniversary
edc's Avatar
I have a UK made version of this. I can't say it stops axle tramp and I can't say I notice much difference in day to day driving. Hard to tell the difference when driving in extremis as I'm not measuring lap times and only going by feel.
Old 03-18-2015, 04:44 PM   #15
Luv2Box's Avatar
I have a Tip so it's hard to get wheel hop and I've never experienced it but it does strengthen the suspension much like a strut tower bar. My trusted mechanic stated "it can't hurt." I only posted it for you as a lead so you could contact Pedro and ask him questions.
Old 03-18-2015, 05:40 PM   #16
Need For Speed
KRAM36's Avatar
A bit more expensive, but if you really want to beef up that area, here you go.
Porsche Boxster 986 Rear Lower Bar Member Brace 4POINTS | eBay
2003 Boxster S
Old 09-30-2015, 01:59 PM   #17
WillH's Avatar
So are the braces stopping wheel hop or is a limited slip dif the only real cure?
Old 09-30-2015, 07:14 PM   #18
I know. all of our other cars are automatics. I put him in one of the old ranch trucks a couple of weeks ago but its nearly impossible to stall. low gearing and big diesel engine.
