-   -   Why does my "Low Gas Light" indicator stay on? (http://986forum.com/forums/boxster-general-discussions/56200-why-does-my-low-gas-light-indicator-stay.html)
SvenskaPoika 03-09-2015 06:53 AM
I just filled up my 1998 Boxster but the "Low Gas Light" indicator is still on --- even after restarting the car a few times.
Any advice would be appreciated.
hemonu 03-09-2015 07:42 AM
I have the same problem on my 02S, if i run the tank almost empty. Indicator stays on and needle stays down also (even goes down further, as the remaining fuel is calculated from consumption!). After a few days it always comes back. I think that the sensor is most likely blocked at the low end. Up to now I have not changed it, as it is a quite expensive part combining sensor and fuel pump. For a 98 model you are better off, as the sensor can be changed separately and you can find some used ones via eBay etc.
