-   -   Ughhhh wrong MAF part (http://986forum.com/forums/boxster-general-discussions/56033-ughhhh-wrong-maf-part.html)
BIGJake111 02-28-2015 04:46 PM
Ordered a MAF part for the car, based on chassis number it appeared the 2000 boxster s needed the .124 part. Pulled the old sensor and it was a 125.01. So I can't update the computer either. Fingers crossed that pelican has a good return policy.
KRAM36 02-28-2015 05:41 PM
Did you even try it?
This has as lot of info on the maf sensor. Maybe you can figure out something from this.
Air Cleaner
99660612400 mass air flow meter f >>98ys6 20414>> f 98ys6 60257>> see technical information group 2 nr. 1/00 information available.
98660612501 mass air flow meter f >>98ys6 20415>> f 98ys6 60258>> see technical information group 2 nr. 1/00
BIGJake111 02-28-2015 07:33 PM
I did not try it, but it is older than the current part in the car, and to my knowledge the software cannot be back dated.
KRAM36 02-28-2015 07:50 PM
********************************************.com says that part number is used in years 2000 and up. I'm not sure what the numbers I put in bold means, but both part numbers were used on a 3.2l motor 2000 and up.
BIGJake111 02-28-2015 09:42 PM
according to pelican the part I ordered was used in the very first e gas 2000 cars, to quickly be replaced by the other part. The issue is the part I pulled from the car happened to be the newer part, rather than the early e gas part.
KRAM36 02-28-2015 09:45 PM
My car has the 125.01 sensor too. Not sure how Pelican is with exchanges, but they do charge a 15% restock fee on returned items.
BTW: Pelican has the wrong maf sensor listed for the 2004 special edition cars. It should be 98760612500, not 98660612501.
BIGJake111 03-01-2015 07:01 AM
Will be calling them tomorrow to see what I can do, the other sensor is about $40 cheaper so price shouldn't be too far off in the end anyway. In the case they cannot return I guess I will just need to sell the new MAF I bought online.
