Old 02-28-2015, 04:46 PM   #1
BIGJake111's Avatar
Ughhhh wrong MAF part
Ordered a MAF part for the car, based on chassis number it appeared the 2000 boxster s needed the .124 part. Pulled the old sensor and it was a 125.01. So I can't update the computer either. Fingers crossed that pelican has a good return policy.
Old 02-28-2015, 05:41 PM   #2
Need For Speed
KRAM36's Avatar
Did you even try it?
This has as lot of info on the maf sensor. Maybe you can figure out something from this.
Air Cleaner
99660612400 mass air flow meter f >>98ys6 20414>> f 98ys6 60257>> see technical information group 2 nr. 1/00 information available.
98660612501 mass air flow meter f >>98ys6 20415>> f 98ys6 60258>> see technical information group 2 nr. 1/00
2003 Boxster S
Old 02-28-2015, 07:33 PM   #3
BIGJake111's Avatar
I did not try it, but it is older than the current part in the car, and to my knowledge the software cannot be back dated.
Old 02-28-2015, 07:50 PM   #4
Need For Speed
KRAM36's Avatar
********************************************.com says that part number is used in years 2000 and up. I'm not sure what the numbers I put in bold means, but both part numbers were used on a 3.2l motor 2000 and up.
2003 Boxster S
Old 02-28-2015, 09:42 PM   #5
BIGJake111's Avatar
according to pelican the part I ordered was used in the very first e gas 2000 cars, to quickly be replaced by the other part. The issue is the part I pulled from the car happened to be the newer part, rather than the early e gas part.
Old 02-28-2015, 09:45 PM   #6
Need For Speed
KRAM36's Avatar
My car has the 125.01 sensor too. Not sure how Pelican is with exchanges, but they do charge a 15% restock fee on returned items.
BTW: Pelican has the wrong maf sensor listed for the 2004 special edition cars. It should be 98760612500, not 98660612501.
2003 Boxster S
Old 03-01-2015, 07:01 AM   #7
BIGJake111's Avatar
Will be calling them tomorrow to see what I can do, the other sensor is about $40 cheaper so price shouldn't be too far off in the end anyway. In the case they cannot return I guess I will just need to sell the new MAF I bought online.
