Old 02-05-2015, 10:29 AM   #1
thom4782's Avatar
P0430 - Help Interperting Symptoms
i everyone:
Last week the CEL lit up and the Durametric found a P0430 fault. IIRC, this means that the aft O2 sensor on Bank 2 was above limit. Today, the CEL turned off by itself.
I've seen P0430 a couple of times before. I got a CEL about 4 months ago indicating a minor fuel system leak. After clearing the fault, the CEL lit up a couple of more times with the same minor leak fault. One or two times, the leak code was accompanied by a P0430 code. I had the fuel system leak fixed and that code hasn't returned. As I mentioned above, the P0430 code appear by itself for the first time last week.
I know several conditions can throw a CEL and P0430 code. So I have a couple of questions:
  1. What do you think the odds are that the P0430 code is a false positive and nothing is actually wrong
  2. How can I test to see if the catalytic converters are operating correctly?
  3. Do you think the fuel leak problem in the past could have made the MAF dirty
  4. What are the odds that this might be a exhaust leak issue
I'd appreciate your suggestions before I toss a couple of thousand at replacing the cats. Here in CA, we can buy aftermarket cats
Old 02-05-2015, 08:49 PM   #2
Jager's Avatar
This thread might help you:
http://986forum.com/forums/general-discussions/47002-calling-986-forum-master-mechanics-2.html
Jäger
300K Mile Club
Old 02-05-2015, 10:32 PM   #3
Need For Speed
KRAM36's Avatar
P0430 is
Porsche Fault Code 45 cat conv. efficiency bank 2
It does seem other problems can trigger this code.
Look at my thread here Trying to wrap my head around fault code P0430 and P0420
I'm still waiting to get my car back from the body shop to see if the new knock sensors will stop the P0430 code.
Old 02-07-2015, 07:14 AM   #4
thom4782's Avatar
Thanks...very helpful
Was disappointed to see the comments on octane level. Yesterday, I pulled up to the Chevron pump while thinking about a work issue. Didn't pay attention and filled the tank with regular (87 octane). Will take a long drive today to use half the tank and refill with premium.
