12-18-2014, 12:47 PM
Beginner
My gas mileage is improving
My gas mileage has gone from 18.0 to 20.1 with no change in driving habits. Could it be the winter fuel blend? Always use the same brand of premium.
2003 S manual
12-18-2014, 01:22 PM
If you're in Houston, perhaps you are using the A/C less in the fall/winter?
I would think winter fuel would decrease your mileage, but not sure on that one.
12-19-2014, 10:11 AM
Beginner
I'll bet you are right on the AC. In summer it's just left on, now I cycle it occasionally. It's still usually on, but on a dry morning it's turned it off.
2003 S manual
12-19-2014, 10:25 AM
Don't summer gas blends have more Ethanol ?
12-19-2014, 11:04 AM
For a point of reference in summer (hot as hell Phoenix) I get between 21 and 22.5 mpg. In mild weather it will move up to 23 to 24. Once it gets really cold (for Phoenix that's in the 30's in the early morning) it drops back down to 21 to 22.5. When it's hot it's the AC and when it's cold it just takes longer for the engine to warm up to an efficent operating temp. Throw in some more ethanol dependng on the blend being used in your area for the time of year and that will also impact mileage. I find how you drive it impacts mileage more then anything else. At the track I drop down into the low teens.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
12-19-2014, 11:52 AM
Yes. 7-9%.
Winter blend is more like 5%.
This is what I saw a couple years ago with my test kit. Easy to do.
12-21-2014, 07:52 AM
MPG city highway elevation
I live in Colorado. My commute is 27 miles one way. I'm at about 6200 feet. My commute is all highway miles. I get between 28-31 depending if I have to puts around town before heading home. I have a 99 with the 2.5l and a 5 speed manual. The highest octane fuel I can get is 91 and it has up to 10% ethanol in it. I accidentally put 87 octane in once and it felt like I was driving a Honda Civic. The power drop was frightening. I added octane booster and kept adding 91 as frequently as I could to get that low grade stuff out of there.
02-05-2017, 08:54 AM
Winter gas blends have less energy in them than summer. But not all locations do the switch and not all at the same time. On the car forums where fuel economy is the constant subject, you see this remarked about all the time. Some use fuelly.com to monitor every tank of gas since the car's second tank.
02-05-2017, 08:59 AM
Yeah that doesn't sound like fun to me. I was just surprised my the improvement I've seen. It does not seem to make sense to me.
What I did leave out is that I have a 5-speed and during this time of "improved mileage" I've also been driving with the top down more. It's pretty much perfect in the Phoenix area now!!
So the improvement seems weird to me...hence the post.
Thx!!
02-05-2017, 09:09 AM
So Blessed!
I have a friend who has a immaculate restored 1936 Phaeton. It's like the one President Roosevelt drove, but without the levers Roosevelt needed. He only uses Marine fuel in the car to preserve fuel hoses, etc. Not saying to use it in the Porsche. But just a thought and the octane should be OK.
02-05-2017, 01:32 PM
So no electrical load from fans, no parasitic drag from the A/C. Somehow I think the Kamm effect would help more with the top up than down though.
I'd envy you your weather but I've been in Phoenix too many times when the temp was over 100 after 8 at night to want to be there year round.
02-05-2017, 02:47 PM
Artist, 986S tinkerer
one must consider that these engines run more efficiently at cooler temps., i.e. cooler inducted air.
02-06-2017, 07:47 AM
I'm wondering what method you are using to estimate fuel mileage?
Pump gallons/odometer is most accurate. If you are using the built in computer mileage gauge then be sure to reset it at a new tank of gas to get a good avg read.
Otherwise its just a cumulative average including the time it sits idling in the driveway, waiting to pick up kids after school etc etc and skews the results a bit.
