-   -   headlight switch replacement question (http://986forum.com/forums/boxster-general-discussions/55037-headlight-switch-replacement-question.html)
Jamesp 12-06-2014 06:21 PM
I've looked for posts on replacing the headlight switch but not found anything. Anyone have a link to a good headlight replacement thread? Any advice on doing this?
kjc2050 12-06-2014 06:48 PM
Pelican Technical Article: Boxster Headlamp Switch Replacement - 986 / 987
JayG 12-07-2014 07:21 AM
Before you replace it, you can squirt it with tuner or contact cleaner\
Just squirt the cleaner into any hole you can find in the switch and down the shaft.
Then work the switch a bunch
Mine was acting up and it cleaned it and have had no issues since then
You still do need to pull it out first
