-   -   OBC switches (http://986forum.com/forums/boxster-general-discussions/54888-obc-switches.html)
jim_hoyland 11-22-2014 07:41 PM
OBC switches "Poor man's version"
I did the DIY single switch mod so I can cycle through the functions; I have a couple of question for those who have done the 1 switch and 2 switch mods:
Some articles recommend installing two switches on the dash face; does the second switch allow for activation of the speed gong ?
My switch cycles through the function by pushing one side of the switch, pushing the other side doesn't appear to do anything; is this normal ?
My box is a '98
Timco 11-22-2014 09:37 PM
My OBC has one arm. Push front and back to select or go back a screen, up and down to scroll or change values.
kjc2050 11-23-2014 03:57 AM
Jim, like Timco, I have the 4th stalk, but I would assume that the answer to your question is "yes," based upon the following excerpt from the Pelican technical article:
Wire one of the two switches to the pins that control “mode forwards” and “mode backwards”, and the other switch to “select mode down” and “speed gong/alert” (see table in the text).
jim_hoyland 11-23-2014 08:02 AM
I've read the Pelican Tech article several times; before and after my dash switch installation. I'm seeking feedback from those who did the "poor man's OBC" using one and/or two switches.....thanks for the feedback. :)
kjc2050 11-23-2014 09:55 AM
You're going to need two switches, working in concert with one another, to adjust the speed at which the speed gong sounds.
jim_hoyland 11-23-2014 01:30 PM
Did you do this ?
kjc2050 11-23-2014 01:31 PM
No. See the PM I sent you. Shot a quick video to try to explain how the stalk works. The switches must operate in the same fashion.
jim_hoyland 11-23-2014 01:38 PM
Great description for stalk operation !
