Old 11-27-2014, 03:51 PM   #21
Originally Posted by jaykay View Post
I am pretty sure you have cable operated releases. Nevertheless they do get locked up by a local solenoid once the battery dies.
So if the battery dies, and it locks by local solenoid. Whats the use of running an emergency cable for when the battery dies. Seems the cable would be useless if it locks by local solenoid.
1997 Boxster! (Tiptronic)
brjak is offline   Reply With Quote
Old 11-27-2014, 07:25 PM   #22
jaykay's Avatar
The levers that pull the release cables are prevented from moving, however you can still pull the release cable via other means if you can get to it. There is a emergency cable that is looped around the main release cable; pulling it will unlock your frunk latch.
IIRC this cable is stuffed under the right front fender liner...( please verify as I changed this many years back) and hard to get to. Many have rerouted such that it can be used when needed.
986 00S
