-   -   A question for those who have replaced the water pump (http://986forum.com/forums/boxster-general-discussions/54848-question-those-who-have-replaced-water-pump.html)
Pdwight 11-19-2014 07:55 PM
I have a good sized job coming up, new trailing arms, new parking brake shoes, rebuild or re lube and install new boots on the CV joints and new wheel bearings on the rear.....also in that lineup is a new Motor Mount...I have everything sitting in my garage and I was pondering the question. Is it a lot easier to replace the water pump once you have the motor mount off ?
My water pump is not giving me any problems, no noise, no leaks nada....but my Bavarian Beauty just turned over 70 K miles and well...should I or wait for problems ??
Dwight
ChrisZang 11-19-2014 08:06 PM
Dwight
It makes no difference if the motor mount is on or off
You write "my Bavarian Beauty" did you accidentally buy a BMW and think it's a Porsche? Porsches are not from Bavaria. Hint: if the engine is up front it's actually a BMW ;-)
Pdwight 11-19-2014 09:03 PM
Yes a Typo
I do have a E36 with 147K on the Odo and it is one of the best cars ....if not the best car I have ever owned
PS I appreciate the info on the water pump.
Timco 11-19-2014 09:51 PM
http://i868.photobucket.com/albums/a...pseecabcd6.jpg
NewArt 11-20-2014 04:36 AM
Wow. Don't think I'd be using the Cos as my surrogate to post a comment right now...
Timco 11-20-2014 04:50 AM
The Cos didn't drive Ms. Daisy.......
http://i868.photobucket.com/albums/a...ps4fa7764c.jpg
NewArt 11-20-2014 05:40 AM
Haha. Shoot me, I'm stupid. You're right of course!
mikesz 11-20-2014 05:45 AM
I replaced my water pump, thermostat, and front motor mount. check out Pedro's diy. Once you take out the motor mount the water pump is a breeze. I removed the engine cover inside the car and got it up on jackstands to get underneath.
mikesz 11-20-2014 05:47 AM
Keep us posted on your suspension refresh. I am planning on doing same with my 99 DIY. But may hold off due to co$t!
bwillia080261 11-20-2014 09:48 AM
That would be a Swabian beauty!
san rensho 11-20-2014 10:31 AM
It is much easier to replace the WP with the motor mount removed. You can get a torque wrench on every WP fastener.
Giller 11-20-2014 10:44 AM
RIP Morgan Freeman?
Timco 11-20-2014 10:54 AM
Originally Posted by Giller (Post 425718)
RIP Morgan Freeman?
http://i868.photobucket.com/albums/a...pszhlxp98c.jpg
BFeller 11-20-2014 11:47 AM
Nice baiting in the thread Timco.
I understand that taking the water hoses off to drain the coolant makes it easier to drop the front engine mount during removal of the mount. Being able to torque all of the water pump bolts is something I did not know could be accomplished with the motor mount out of the way.
Timco 11-20-2014 11:51 AM
Just stuff I find online. There's great ones.
http://i868.photobucket.com/albums/a...ps7ym5ocwv.jpg
BoxsterSteve 11-20-2014 01:22 PM
Torque wrench is nice, but not necessary. I just snugged the water pump bolts up, and gave them another quarter turn.
The vacuum fill tool held 25" of vacuum for a half hour, so I surmised I was leak free.
dghii 11-20-2014 05:47 PM
I'd hold off on the pump as you have no symptoms and your upcoming tasks are not related to the WP so there is no "while I'm there" cost or time savings.
and I just replaced my WP at 119K miles due to a small drip. After getting to the pump, I just saw a small drip from a lower bolt. Since I was in that far and had the part on hand, I went ahead and replaced the WP and thermostat. After removing and inspecting the (original) pump, I noted no bearing play or wear to the pump veins
Given small torque spec for the WP (12-14 Ft-lbs) I'm fairly certain that I could have re-torqued the bolts a and been good to go. Looking back, I should have tried it.
I even kept the old pump!
Pdwight 11-20-2014 06:16 PM
Thanks Folks
Jager 11-20-2014 10:07 PM
I found that a 10mm deep well socket with 1/4" drive will be your friend when replacing the water pump.
CoBeerToad 11-21-2014 11:43 AM
I did both a few months ago. I don't think it would have made that much difference.
