View Poll Results: Does your Boxster Rattle ?
It does not rattle at all 35 36.08%
It gores away very quickly 56 57.73%
It rattles until it get to 180 deg. (or normal temp) 3 3.09%
It always rattles 3 3.09%
Voters: 97. You may not vote on this poll
Old 08-06-2017, 06:11 AM   #21
kk2002s's Avatar
Most typically the chain tensioners
They need to pump up a bit
Mine does the same when it sits for days on that first start
Old 08-06-2017, 06:44 AM   #22
still plays with cars...
BoxsterSteve's Avatar
The standard M96 start up chain rattle.
I'll change the IMS chain tensioner at oil change time in the fall just in case it's gotten lazy in the last 17 years.
Six speed 2000 Boxster S
Old 08-06-2017, 07:49 AM   #23
Mine does it after sitting for a week or so on first startup. 2001S with 99K miles. I changed all three chain tensioners with new ones over the winter and it did not help one bit.
dsallean is offline   Reply With Quote
Old 08-06-2017, 08:17 AM   #24
I seem to remember someone saying you need the updated oil pressure relief valve, the little piston and spring to fix the rattle start up. Somehow the old ones start leaking after a while and the oil bleeds out and the tensioners rattle.
bwdz is offline   Reply With Quote
Old 08-06-2017, 08:32 AM   #25
redciv1's Avatar
Very interesting., Will definitely have to check out! Thanks.
redciv1 is offline   Reply With Quote
Old 08-06-2017, 08:37 AM   #26
WillH's Avatar
Rattles for a second at startup but "gores" away quickly
Same as my KTM or the primary chain on my Norton. Just takes a second for the guides to pump up.
Old 08-06-2017, 10:52 AM   #27
BYprodriver's Avatar
Originally Posted by lkchris View Post
Sounds like lifters or cam chain to me, but my mechanic says that rattle--only when really cold and not run for a few days--can be IMS bearing.
Sounds like you need a new mechanic & new 2002 ims tensioner with preload spring!
