Old 10-19-2014, 10:38 PM   #1
KylesBoxS's Avatar
Unhappy Strange Problem! Any Experience with this?
So on Saturday I had the weirdest thing happen. We were autocrossing my 2000 Boxster S, but with 3 drivers taking turns driving the car, so it was running practically all day. Then before the last run of the day I start it and smoke comes out the exhaust (both water and oil) so immediately I think blown head gasket of that sort, I buy coolant and oil and decide to try to drive home after topping all the fluids off (which were only slightly low). However on the way home the car stops smoking, and looses no fluids. After driving for another 2 days no smoke, no fluid loss. I checked the temperature the entire time we were racing it and the temperature was stable for the most part, didn't get close to overheating. I'm so confused at this point did it fix itself?! Has any body had this problem or know what it could be? :ah:
Lifes too short to NOT drive a Porsche.
KylesBoxS is offline   Reply With Quote
Old 10-19-2014, 10:43 PM   #2
Track rat
Topless's Avatar
Maybe just a little oil in the cylinders. Check your oil and coolant color and level. If they look normal you are probably fine. Watch your oil level over the next few weeks for any signs of loss.
Old 10-20-2014, 07:37 AM   #3
Motorist & Coffee Drinker
78F350's Avatar
I'd pull the oil filter and housing to check for any debris or mixing with coolant. Its easy enough to do with minimal loss of oil.
Old 10-20-2014, 08:55 AM   #4
BYprodriver's Avatar
AOS let some oil get sucked into the intake?
Old 10-20-2014, 09:22 AM   #5
You certain it was coolant? Could have just been water vapor from normal combustion. And depending where the engine stops everyone gets a nice blast of blue smoke once in a while.
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
peterbrown77 is offline   Reply With Quote
