Old 10-19-2014, 09:02 AM   #1
Replacement engine numbers 1998 Boxster
i was performing some maintenance on my 98 boxster last weekend and noticed my engine stamp had an unusual looking "R" on the end of the series. I am the fourth owner of this boxster but the previous owners failed to include maintenance records.
Does the "R" stand for replacement ?
Paul Ri-Chard
Paul Ri-Chard is offline   Reply With Quote
Old 10-19-2014, 09:22 AM   #2
Chuck W.'s Avatar
I believe that is the part number for the valve cover.
Your engine number will look like this.
1995 Porsche C4 Cab
Old 10-19-2014, 09:38 AM   #3
No, you are looking at a part number, not the engine number. And if it were a factory replacement engine, it would contain the letters "AT".
Old 10-19-2014, 10:42 AM   #4
The engine stamp serial # is viewed from top or bottom or bottom of engine. Near tranny or starter as in your picture ?
Paul Ri-Chard
Old 10-19-2014, 10:49 AM   #5
It is on the oil sump rail.
Old 10-19-2014, 11:28 AM   #6
Motorist & Coffee Drinker
78F350's Avatar
In case, like me he's not sure what an 'Oil Sump Rail' is:
That's the bottom of the engine, right side. It is just forward of where the O2 sensor sticks out from the exhaust.
Old 10-19-2014, 12:36 PM   #7
Chuck W.'s Avatar
And, it will most likely gunked over. Look for a flat spot and rub there.
1995 Porsche C4 Cab
Old 10-19-2014, 11:30 PM   #8
Got it, thank you !😊
Paul Ri-Chard
Old 10-20-2014, 07:18 AM   #9
Engine Surgeon
It can also have an "X" in the number to identify a reman engine.
US Patent 8,992,089 &
US Patent 9,416,697
Old 10-20-2014, 07:38 AM   #10
Track rat
Topless's Avatar
The "R" stands for "Race" and should be always painted red.
