Old 09-07-2014, 07:50 PM   #1
husker boxster's Avatar
Kudos to Woodhouse
With all the negative stories about stealership nightmares, thought I'd pass along a good story about Porsche of Omaha (Woodhouse)...
I recently noticed when I'd close the top on my LE, the canvas part of the top would slip over the outside of the bottom plastic bow on the passenger side. This left the seam in a very tight / stretched condition that couldn't be good for the stitches of the seam. So whenever I was putting the top up, I'd have to stop it 4-6 in from the windshield post, get out, help the canvas inside the bow, and then finish the top up process.
I stopped by Woodhouse on Thu to see what they thought of it. I wasn't sure if it was caused by some adjustment they made while fixing my broken cables adventure a month ago. The SA said no, it wasn't related. Our tops are held in place by a series of cloth straps and nylon strings (I hope they're nylon) that stretch with age. He said the staps could be reached by undoing some velcro strips that keep the headliner in place and unscrewing some torx bolts to adjust the straps. We set up an appt for Wed to have them fix it but he said I could cancel if I wanted to try and fix it myself.
So I finally had some time tonight to take a shot at it. There are two straps and a nylon string that keep the canvas tucked in. I tried adjusting the smaller of the two straps, but it didn't seem to move. Upon further review, it looked like the string might be the culprit. It ran inside a channel of the bow and out to the top. It was held inside the channel by an elastic band but the band looked like it was stretched out, allowing the string to have less tension on it. I rotated the band to the place where it was sown together, thinking that might be stronger and hadn't been stretched yet. But it still seemed to allow more tolerance than it should. So I got a small zip tie and placed it high enough on the band to keep the string from distorting the band but low enough that it wouldn't rub on the string. And I made sure the female part of the zip tie wouldn't rub against any of the headliner.
Vuala! The top closes like it should. I did the same procedure on the driver's side because it was looking a bit stretched too. It's kind of scary how such delicate fabrics are responsible for some important work.
So back to the reason for the thread - Woodhouse didn't need to tell me how to fix my top. They could have said , "yeah, we can fix that". So now I can cancel my Wed appt and save a cpl Benjamins. Sweet!
Kudos to Woodhouse. :dance:
1989 928 S4 5 spd - black
Old 09-08-2014, 12:41 PM   #2
BruceH's Avatar
Nice! Glad you got it fixed plus saved some cash in the process, always a good thing and yes, it was nice they gave you some pointers to get it fixed
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 09-08-2014, 01:02 PM   #3
Giller's Avatar
Good story. As much hate as there is for dealerships - there are a lot of good ones out there with good people.
Yes they charge more than an indy shop - more employees with much more overhead than a small shop.
They are a business and they don't work for free (neither do any of us) - so it is nice when they step up with some free advice!
Old 09-08-2014, 08:32 PM   #4
Zip ties and duct tape the only way to go. oh dont forget super glue and wd40
nicecar is offline   Reply With Quote
Old 09-09-2014, 07:52 AM   #5
The elastic straps on my top are all stretched out from prolonged top-down status when the first owner kept a hard top on the car for years on end.
So I'm always stopping the top 6 inches from the latching point and putting the top back into the side guides on both sides.
It's really frustrating. Chop the window on the way down and do this on the way up!
I'd just replace the whole top with a retrofit glass window unit, but I don't want to put another dime into this car and save it for the next!
