Old 08-21-2014, 06:44 PM   #1
Multi-Boxer Driver
Deserion's Avatar
Crunchy regulator?
So funny thing. When I was leaving work, I noticed the car sounded more "open", so I opened and closed the passenger door (had a coworker ride to lunch with me). Then I hear the glass grabbing along the roof.
Short story: When the door handle is pulled the window tries to drop. I can see the minor movement, I can hear the motor working, the interior lights engage, but the window won't drop. However, if I open the roof the window goes down as normal, and works as it should. It works correct with the switch, and when the door is open, still leaves the appropriate gap to allow proper closure (and zips up shut). It just can't seem to drop when the handle is pulled.
I am getting a little crunching on occasion when the window is closing (almost closed). So I'm figuring it's the regulator in need of replacement. What say you guys?
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 08-21-2014, 07:15 PM   #2
replacement is soon, from my experience
nicecar is offline   Reply With Quote
Old 08-21-2014, 08:06 PM   #3
On the slippery slope
JayG's Avatar
The regulator definitely has a problem. You may be able to salvage it with a bike brage adjuster if it is simply stretched. YMMV
There are some threads on it here
Mine did the same thing as yours and I replaced it
You may have a microswitch problem in the door lock as well
2004 996 Targa Tip
Instructor - San Diego region
Old 08-21-2014, 08:20 PM   #4
Multi-Boxer Driver
Deserion's Avatar
The crunching is definitely getting worse now. New regulator time, then.
-Chris
Old 08-22-2014, 09:07 AM   #5
regulator repair
omega charged 225 i think. less than my chevy and ford however I no longer use that garage. The only reason I did not do it is I have seen a couple come into the garage for door clips etc. which just opens a whole new can of worms for me.
