Old 08-19-2014, 05:23 PM   #1
Crankcase pressure results - is 5.8 bad?
I've been under the impression my AOS needed to be replaced. I'm burning through about 3 quarts of Mobile1 over each 5000 mile oil change interval. My AOS is 16,000 miles old and there is a slight amount of liquid oil in the tubes between the AOS in the intake. However this evening I connected a pressure gauge to my oil tube and am only pulling 5.6 - 5.8 inches at idle. I hear 5 inches is normal.
Is 5.8 inches reflective of a bad AOS?
Old 08-20-2014, 02:32 AM   #2
Depends upon inches of what. You should be around five inches of water, while most vacuum gauges are in inches of mercury, where 1 inch of water equals 0.0735 inches of mercury. So if your gauge is in inches of water, you are fine; however if it is in inches of mercury, you are in trouble.
JFP in PA is offline   Reply With Quote
Old 08-20-2014, 06:28 AM   #3
Yes inches of water.
Old 08-21-2014, 07:09 AM   #4
Any thoughts to why my AOS is passing oil but pressure readings are normal? Should I replace it or not?
Old 08-21-2014, 07:44 AM   #5
Registered Boxster abuser
healthservices's Avatar
how many miles on motor?
Old 08-21-2014, 08:30 AM   #6
The AOS will pass oil well before it totally craps out. Yes, I would replace it,
Old 08-21-2014, 09:26 AM   #7
About 62,000.
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
Copyright 2024 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
