09-08-2014, 03:22 AM
#21
Originally Posted by epapp
Did you check the engine compartment temp sensor for proper functionality?
Nope. It has to be related to the coolant level sensor since disconnecting it causes the light to stop flashing. Otherwise implies that they are wired in series, which doesn't make sense - even for Porsche hahah.
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
09-08-2014, 08:58 AM
#22
Oh, I missed the part where disconnecting it made a difference in the light, my bad.
Yeah, probably something in the tank then, since you replaced the complete switch. Maybe replace the tank if it is yellowed and old anyways? Or just leave the sensor unplugged and YOLO a little bit...
09-08-2014, 10:21 AM
#23
I installed a new tank in May when I did the IMS..... no way I'm taking that thing out again!!
11-10-2017, 11:54 AM
#24
Any luck with the light
were you ever able to figure out what was wrong. I have 1999 doing the same thing now
John
11-10-2017, 05:29 PM
#25
1997 Tip, 2018 Macan
FYI, this thread is over 3 years old. You may not get a response from the OP.
11-13-2017, 05:15 AM
#26
I didn't... as a matter of fact, I had the carpet out this spring and connected the sensor again and it started flashing so it's disconnected again.
07-19-2020, 09:00 AM
#27
Thanks for the insight
I know this is an old thread, but it was really helpful. I have a similar problem that I have been trying to diagnose. I replaced the coolant cap, engine compartment temperature sensor and coolant level sensor, but still the light keeps blinking. I have tried to check the wiring with the assumption that the circuit is normally closed when the coolant is topped off. This thread gave me the tip that full = normally open. I disconnected the connector to the coolant sensor and the light went off. Real progress! Thanks
Now I need to figure out why the circuit is closed with the connector attached and full on coolant, but that should easy now that I understand the system logic.
07-19-2020, 09:19 AM
#28
Yeah, this is old! Sold the car years ago, never did figure it out. Just left it disconnected. Still see that car driving around tho! New owner is definitely in over his head.... Explained oil changes to him and he said he would just let the dealer do it. This from a guy with 3 teens/tweens, a tiny house and college on the way.
07-19-2020, 09:20 AM
#29
Yeah, this is old! Sold the car years ago, never did figure it out. Just left it disconnected. Still see that car driving around tho! New owner is definitely in over his head.... Explained oil changes to him and he said he would just let the dealer do it. This from a guy with 3 teens/tweens, a tiny house and college on the way.,and couldn't drive a stick
07-21-2020, 04:57 PM
#30
Just a follow up. My problem is solved. It was a stuck float. The float was stuck at a low fluid level even though the coolant was topped off. I figured it out by pushing down on the float with a screw driver to check the function of the switch while a VOM was attached to it. It was then I discovered the switch worked right when pushed on the float a couple of times.
The crazy thing is I have driven it over 2000 miles with that light blinking! So it was stuck all that time.
The simplest things sometimes.
