I am in the process of installing a 76mm throttle body and a custom cold air intake. I took everything off and removed all of the bolts I need to but I still can't remove the intake manifold or the air box. I followed the pelican instructions but I believe that is for the 2.7 not the 3.2 I have. Everything is loose but won't come out because there store some pipes runnin. In between the manifold. If others with a 3.2 have done this please chime in. I really need some help here because I am without a car until I finish this. Thanks in advance.
