Old 07-31-2014, 11:44 AM   #1
Normal Operating Temp ????
I know it depends on various climate conditions but what is the normal operating temp. for a boxster ? Mine seems to be running slightly hotter than it used too. About 190 ..... Oil level is fine, coolant level slightly low but at the same level it's been at for years.
gmboxster is offline   Reply With Quote
Old 07-31-2014, 01:52 PM   #2
epapp's Avatar
How are you getting the 190 reading? From the dash gauge?
Old 07-31-2014, 02:04 PM   #3
I believe turning on your AC will also make your engine run a little hotter. The temperature guage is not particularly accurate either. Engine is almost always at a higher temperature than suggested on the guage.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 07-31-2014, 02:29 PM   #4
flaps10's Avatar
I've only had my 20-ish mile drive home but had the same question, so I'm glad someone else is asking.
My manual says the needle should be in the middle (which mine is doing).
I initially thought the temp was high because it was north of 180. However I had to remind myself that 180 is a great oil temp, and that coolant gauges don't often have a number, just a range.
Old 07-31-2014, 02:40 PM   #5
tonycarreon's Avatar
the stock thermostat starts to open around 190º
Old 07-31-2014, 03:04 PM   #6
My 190 - 200 is referring to the oil temp gauge. Normally in the past it would register ever so slightly north of 180. I'm just wondering if it's something I should be concerned about. BTW the AC was off and it was fairly cool here today. Outside temp about 72F.
Old 07-31-2014, 03:12 PM   #7
The OEM thermostat in the M96 starts to open at 186F, and typically is not fully open until nearly 210F. The dash gauge is typically way off, indicating around 180 or so when the actual coolant temp (read by a Porsche specific scan tool or an after market temp gauge) is commonly around 205-215F at steady state. Along with the dash gauge being nearly useless, the data you get from the AC panel is a often close second in inaccuracy.
With the oil usually running at least 10-15 degrees hotter than the coolant (steady state cruising, start pushing the car, or running it on a very hot day and the oil can get even hotter).
Old 07-31-2014, 04:30 PM   #8
Rennzenn
j.fro's Avatar
Here's my experience on the same question; looking forward to input. I've got the Dash Command app and the elm wifi transmitter. In my 1999 996 C4 on 95+ degree days I'll see coolant temps stabilize around 216 running 71 on the highway. In highway traffic accelerating/decelerating, temps get to 221, but no higher. On cooler days, temps never get that high.
How hot is too hot?? 225? 235? 245? 250?
FWIW, my 986S with center radiator and hood vents never gets over 219, and cools down to 180 quickly once we're moving.
Rennzenn
Jfro@rennzenn.com
Old 07-31-2014, 05:22 PM   #9
OK, here's the problem: When the overall temp is 216F, there are parts of the engine that are hotter, and some that are cooler. That differential is not particularly good for an alloy cased engine, and the thermal loading contributes to things like cylinder head cracking.
Secondly, if the coolant is at 216F, the oil is probably near 230F, which both shortens its life expectancy as well as reduces its ability to cool the bearing surfaces (one of the principal functions of oil).
Old 08-03-2014, 02:57 AM   #10
Rennzenn
j.fro's Avatar
So 216 is not good. Any thoughts on the solution? Do I need to add a center radiator to the car? The car has 88k miles and I believe the water pump is original (and coolant). Is this a sign the impeller is going?
If this is dangerously hot, any thoughts on why Porsche didn't put the center radiator in all cars? Or why the idiot light doesn't come on until much hotter (250)??
FWIW, in my 986 which runs much cooler, I did an old V8 hot-rod trick: I drilled a 1/8" hole in the T-stat plate so that there is always some coolant flowing. I know the Porsche system already has a bypass in the heater system, but it seems to be part of the difference.
Rennzenn
Jfro@rennzenn.com
Old 08-03-2014, 04:53 AM   #11
This is why you install the LN low temp thermostat, just like Porsche's high performance engines...opens much sooner and stays open to allow coolant flow. Anything to get the temps of both coolant and oil down is good for the engine.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 08-03-2014, 06:03 AM   #12
Clean your radiators and running the AC also kicks on the fan, which can make it run cooler.
runjmc2 is offline   Reply With Quote
Old 08-03-2014, 07:40 AM   #13
Adding the center radiator will give you higher heat transfer capacity, which will change the rate at which the engine sheds heat, but not its steady state temperature. That is controlled by the thermostat.
Old 08-04-2014, 02:35 AM   #14
mikesz's Avatar
My 99 tended to run hotter than I like. A few weeks ago I replaced the thermostat, water pump, and front engine mount. I had the time and do most of the work myself. Car has 80k on it and in a little over a year I have experienced most of the Boxster GREMLINS! So with that said I took the old thermostat and immersed it in boiling water to see if it opened properly. It opened but not all the way and when I let it cool did not close all the way indicating to me it was not working properly. Since doing the work my temp gauge is much more consistent. I also replaced the engine bay fan. it was binding and blowing fuses. Had the same issue with the 2 front coolant fans. I am glad I changed out my thermostat just for piece of mind and the work wasn't all that difficult. You may want to make sure all the coolant fans are working properly also.
99 Porsche Boxster
