-   -   Puddle in front of front right wheel (http://986forum.com/forums/boxster-general-discussions/53373-puddle-front-front-right-wheel.html)
Circles 07-25-2014 05:39 PM
Hi All,
My temperature gauge light began to flash this evening, even though the temp stayed at normal levels. When I got out of the car I noticed drips coming from the body of the car just in front of the front right wheel. I assume that this is a coolant leak, but is this not a strange area for the leak to be?
00' Boxster 986 2.7.
Thanks in advance.
Top_Ramen 07-25-2014 05:57 PM
you should have a small radiator located there bhind the front bumper(and same for the other side and also a third small one in the middle if you have an S) A ripped radiator hose or a loose hose clamp may be a suspect. my .02
particlewave 07-25-2014 06:20 PM
Scraped any curbs lately?
You have 2 radiators behind the front bumper.
Circles 07-26-2014 05:58 AM
Not hit any curbs, but I do remember thinking that something front he road hit the underside of the car a few days back. Should the are in front of the wheel have some sort of cover on it? It looks to me like there is a piece missing on the underside.
thstone 07-26-2014 07:48 AM
Its common to run over junk in the road and tear off some or all of of the underside covers. Scraping the front end on parking blocks will do the same. Do it several times hard enough and its common to crack the radiator where the hose attaches.
Steve Tinker 07-26-2014 06:46 PM
Living in Dublin (Ireland I assume), corrosion of both the coolant and A/C rads is very common.....
You have 2 rads each side just behind the front bumper. Check your coolant reservoir level too.
Circles 07-27-2014 04:27 AM
Coolant reservoir looks like its almost empty, I think ill put it up on the back of a truck and bring it to my indy tomorrow. Thanks guys.
nieuwhzn 07-27-2014 05:31 PM
The 2 radiators and especially their supports are crap.
If you hit a curb then a lot of force is put on the very flimsy bottom support of the radiator. This force gets transmitted to the midpoint support point of the radiator. This midpoint support is plastic and is part of the plastic flow manifold of the radiator. The support point will get a crack at its base and you have nice leak.
Luckily the radiators are not that expensive (~$200 at FPC) and relatively easy to replace.
