Old 07-06-2014, 01:27 PM   #1
Pdwight's Avatar
Instrument cluster question...the piece of plastic that covers the idiot lights
THis is the one major defect in my boxster, the plastic cover that covers the CEL, airbag etc has a break that looks like someone hit it with a phillips driver or something pointed. I need one to replace mine is there a way to get this off without breaking it ??
Dwight
Old 07-06-2014, 02:06 PM   #2
It will not come off easily. You would probably be better off replacing the entire face.
That's too bad. I have a spare cluster but that piece is also cracked on it.
Old 07-06-2014, 02:09 PM   #3
RedTele58's Avatar
Maybe this?
Rennline Stainless Steel Indicator light cover- Porsche-Rennline, Inc.
Old 07-06-2014, 02:19 PM   #4
That's a great option. You could even paint it black for stealth or match to interior trim
Old 07-06-2014, 04:46 PM   #5
Dwight
Mine was cracked, I used nail polish remover(acetone),was very patient to let it seep in and let it sit. It will carefully come off.
MidLife2747 is offline   Reply With Quote
Old 07-06-2014, 04:51 PM   #6
Pdwight's Avatar
Mine
My problem is mine is cracked directly over one of the icons...so the metal cover would be great but it would still be the same.
Old 07-06-2014, 08:24 PM   #7
ChrisZang's Avatar
Is your car a MY2002 or higher (meaning does it have the newer cluster)?
I have a plastic cover laying around that has a straight crack across the "Park" light (it looks much more "dramatic" in the picture than in real live). and with a little patience the crack should be almost invisible.
Let me know if that's what you want, you can have it for free.
On a MY 2002 and higher it's pretty easy to replace that:
* look for DYI instructions to remove the cluster (it's not hard)
* when the cluster is out remove the front face plate (Just be VERY gentle with the two adjusters for time and reset trip counter) when taking them out and especially when putting them back in
* do NOT UNDER NO CIRCUMSTANCES move any of the needles with your fingers, you will damage the fragile mechanisms of the gauges
* Now the plastic face slides straight off
Old 07-06-2014, 08:34 PM   #8
Pdwight's Avatar
I dont want to sound dumb......but ;
HOw do I know if I have one of the newer clusters ??
My car is a 2001 S made in November
Old 07-06-2014, 09:49 PM   #9
ChrisZang's Avatar
old cluster style
new cluster style
Old 07-06-2014, 10:08 PM   #10
I am my own mechanic....
Timco's Avatar
Didn't the older style stack some icons and the newer were all in a row?
'08 VW Touareg T-3 wife's car
Old 07-06-2014, 10:15 PM   #11
Pdwight's Avatar
Yea
New Style...this is also the dot matrix improved version right ?
Old 07-07-2014, 03:35 PM   #12
Oh!that plastic cover, I happen to have an extra one, feel free to in box me if you're interested, I have a few cluster spares, messed up the first one, learned the hard way.. let me know if you need anything else..
