Old 06-11-2014, 01:20 AM   #1
Dipstick stuck!
Hi, first post on this great forum!
My oil dipstick is stuck in the dipstick tube.
I donīt have the guts to rip it out with force, afraid that the little red plastic tip will break off.
Has anybody had the same problem? Solutions? I donīt wanna open the oil pan..
My car is a base Boxster from -97.
Iīm from Sweden so please forgive my swenglish :P
Hormoslyr is offline   Reply With Quote
Old 06-11-2014, 01:29 AM   #2
Steve Tinker's Avatar
Can you twist the dipstick as you try to pull it out?
That might just stop the shoulder (edge) of the red tip catching.....
I'm from Australia so your Swenglish is better than my Engleswed.....
2001 MV Agusta F4.
Old 06-11-2014, 01:37 AM   #3
Tried that but no luck! Canīt understand how it is stuck?
The dipstick is all the way in the tube (as normal), i remember that it took some force to push in last time i had it out.
Is it possible that the stick has folded somehow?
Old 06-11-2014, 01:45 AM   #4
The dipstick won't "fold" but the plastic tube it runs in is known to break between the boot and where the tube enters the engine.
You will have to put the top into the service position to check the integrity of the tube..
Check the search function "end of dipstick came off in tube" for a diagram.
2001 MV Agusta F4.
Old 06-11-2014, 04:28 AM   #5
I will check that, thanks!
Old 06-11-2014, 11:37 AM   #6
The upper tube was cut clean just above the connector.
But now for the sad news, the dipstick broke and it broke in the lower tube. Tried to remove the lower metal tube but the intake manifold is in the way.
How long is a regular dipstick? My dipstick is 63 cm now.
Is the lower tube open at the end? Would be nice to know before i drop the oil pan.
Old 06-11-2014, 12:28 PM   #7
pjq
2004 S
the black curved tube is your dip stick tube, it is flanged too the block with a single bolt. I can't recall how far into the block the penetration goes. The complete dipstick tube is two pieces, this pic is one piece and the 2nd piece starting in your trunk is the plastic piece.
The oil dipstick tube in your trunk , which is plastic, attaches to the end of this tube (in pic) over the collar by a pressure fit clamp, squeeze together between your fingers the 2 grey buttons of clamp.
Old 06-11-2014, 12:36 PM   #8
It goes down deep 10-15 cm i think. Canīt remove it, the manifold is in the way.
My tube was secured by an ordinary 10 mm hex nut not external torx.
Old 06-11-2014, 12:41 PM   #9
pjq
a different angle.
Old 06-11-2014, 03:01 PM   #10
The dipstick is 92cm long including the red plastic end.
If you remove the oil pan (which would be easier than removing the manifold), the remains of the dipstick should be visible and be easy to pull out.
2001 MV Agusta F4.
Old 06-11-2014, 10:12 PM   #11
Ok, thanks! Almost 30 cm left in the tube, it probably canīt go anywhere.
Oil pan is coming off!
But first i will search the engine bay for the dipstick remains, i have a theory: the tube broke first and the dipstick got tangled somewhere in the engine bay.
Old 06-12-2014, 05:21 AM   #12
Theory proved to be true! The dipstick had escaped the broken tube and jammed itself under the generator.
Worst of all, the dipstick had contact to the starters positive lead and when i tried to pull it out it got shorted Disconnected the battery pronto!
I got it out after removing the throttle body and the plenum tube...
All good, now i need a new dipstick and a new upper dipstick tube
