Old 06-01-2014, 12:13 PM   #1
Ashmyster79's Avatar
Send a message via Skype™ to Ashmyster79
Start up rattles
My boxster has been rattling at start up really bad to the point it's quite embarrassing. I took the rubber hammer to it today. I found the culprit. Two heat shields on on either side adjacent to the cats. I was posed with a dilemma. Do I remove them completely which would remove any further rattles or do I grip them tighter to the part they are attached.
I think I read both for and against removal. I opted for this choice. Purely for the fact I think the rattle would come back again. I know they are there for a reason. Above is a rubber boot which I am concerned about and I am sure the heat in the engine bay will have increased but to what level. I will try and fabricate a deflector to bounce the heat back away from the engine towards the road
Anyone with rattles jack up the car get the rubber hammer and tap it around the back I bet the heat shields are responsible. Picture attached of removed heat shield.
Ashmyster79 is offline   Reply With Quote
Old 06-01-2014, 12:53 PM   #2
danch's Avatar
Going to get mine checked as have a rattle on passenger side, as you say nothing more embarrassing than the rattle on startup
danch is offline   Reply With Quote
Old 06-01-2014, 01:10 PM   #3
I noticed a new rattle after changing the clutch, I suspect something like that too...
mgfranz is offline   Reply With Quote
Old 06-01-2014, 03:24 PM   #4
Offroader
ah, ill have to check this also. i get a rattle on start up too.
4runnin is offline   Reply With Quote
Old 06-01-2014, 05:04 PM   #5
Pdwight's Avatar
Tag
FFR
I have the same thing...not too bad...but annoying
Old 06-01-2014, 06:33 PM   #6
jacabean's Avatar
i removed the annoying heat shields almost 4 years ago , no problems at all . while your under there you should remove the secondary cats if you have them and replace with the delete pipes .
Old 06-01-2014, 07:16 PM   #7
Pdwight's Avatar
THis will improve performance ??
Source ??
Old 06-01-2014, 11:42 PM   #8
My only fear was extra heat. I'm wondering if there is possibly a wrap solution like foil that will not make any noise and offer some form heat shield. Not sure if foil is the right material but something like that which is light weight and you can mould tight to the pipes
When driving there were no rattles or over heat. Started up this morning no rattles and first speed bump.....nothing
Get it done if you can. A pair of tin snips or a longish screw driver or for me fingers and brute force just be careful of sharp edges
RATTLE FREE SO HAPPY
Old 06-02-2014, 12:09 AM   #9
Top_Ramen's Avatar
If you're concerned about melting some stuff, you could always just use some exhaust heat wrap. It's relatively cheap and works great.
'99 Porsche Boxster 986 - weekend car
'04 BMW 645ci e63 - daily driver
'98 BMW 528i e39 - dog carrier
Top_Ramen is offline   Reply With Quote
Old 06-02-2014, 12:24 AM   #10
Yes Mota. Exactly what I am after. Thank you. I guess eBay will be where I will find such stuff?
Old 06-02-2014, 02:41 AM   #11
Top_Ramen's Avatar
Usually just got mine from a local race shop but I'm almost positive you can find it on eBay. Just a tip, try to get your hands on DEi brand wrap. I tried out the no-name brand before and the material just feels thin and frayed real easy.
Old 06-02-2014, 03:06 AM   #12
Good old eBay. I have purchased some so should be here in a few days. Have purchased some extra metal cable ties also. Will try and get a picture once done
Old 06-02-2014, 03:09 AM   #13
Doesn't the exhaust heat wrap promote corrosion/rust by trapping moisture ? Or is that not an issue with stainless steel exhaust parts ?
