Old 04-29-2014, 05:26 AM   #1
How to change Temp in dash?
Hello all
After 3 years of ownership, I finaly found how to change the climat control from F to C.
Now can the dash temp be change to from F to C?
Thanks all
Wawa
wawa is offline   Reply With Quote
Old 04-29-2014, 06:00 AM   #2
On the slippery slope
JayG's Avatar
I'm not trying to be an ass, but in 3 years havn't you ever read the owners manual? I got my Boxster a little over a month ago and read the manual as soon as I got it home. Probably looked at it a few more times since....
2004 996 Targa Tip
Instructor - San Diego region
Old 04-29-2014, 07:29 AM   #3
I am my own mechanic....
Timco's Avatar
Keep scrolling and pushing the lever. You'll find it.
'08 VW Touareg T-3 wife's car
Old 04-30-2014, 12:09 PM   #4
Send a message via Skype™ to Gregtenerife
Originally Posted by wawa View Post
Hello all
Thanks all
Wawa
er go on then, how do you do it?
Gregtenerife is offline   Reply With Quote
Old 04-30-2014, 06:12 PM   #5
If by dash temp, you mean the outside air temp, then no, you can't change it. You have to replace the cluster for one that reads in C.
I have the same issue - my dash is fully metric except the analog speedo is mph and the OA temp is F, because it was originally a US car.
'99 black 986
Old 04-30-2014, 07:39 PM   #6
Multi-Boxer Driver
Deserion's Avatar
Hmm, figured the ambient temp. readout would be in C when the rest of the digital readouts on the cluster were switched. As mine doesn't have the OBC enabled I can't test (yet).
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 05-01-2014, 04:44 AM   #7
Hello all
Well after reading my owner manuel AGAIN, still did not find it, lol.
But I read more on the net and I think I found how, but i just cant do it. From what I'm reading, to change the outside temps from F to C, you need to connect the car to a piwis or something like it to change a seting from us to Canada. Then it will read in C.
For the climatic control, if someone need to know:
Hold recirculate then push + & - of the temperature seting
Old 05-01-2014, 06:21 AM   #8
This topic came up once before a while back. At the time, JFP told us that OA temp display wasn't changeable from F to C, except by swapping out the cluster. He didn't mention that doing it via the PIWIS would be an option. I don't have first hand knowledge of this but do place great faith in JFP's knowledge of these cars, and was just repeating what I had been told. Perhaps someone could chime in with the definitive answer. I would much prefer my OA temp display in C if it is possible.
'99 black 986
Old 05-01-2014, 08:01 AM   #9
JayG's Avatar
If you have OBC, you can change it
Go to SET
scroll down to TEMPERATURE
push lever forward
select C or F
push lever forward
pull lever towards you several times until back to display
2004 996 Targa Tip
Old 05-01-2014, 10:36 AM   #10
Ah, that's why I can't change it- I don't have the lever, just the display.
'99 black 986
